1Back to top Go down   Fitting fuel injector Empty Fitting fuel injector on Wed Feb 22, 2017 6:35 pm
Peterk100rs
Peterk100rs
Hi
Im Peter and bought my first BMW K100rs a 92 model. Big had been laying up for four years so it was cold seized when I got it . So It was easy enough to free the engine up and I also replaced the battery and plugs.
So I initially had real problems trying to get the bike to fire up and battery kept going down. So after much head scratching I checked there was A , a good spark B, Fuel get through . So still no joy so last night I decided to pull out the fuel injectors and turn the engine over to see if all where firing . I found number three was not . I also found that the top o ring was had a tear in it .
This morning I cleaned the blocked injector with carb cleaner and checked it was electrically firing ,all good .
This is where I'm in trouble I think , I was fitting the rail with the injectors back into the holes in the block and Im not sure when they are in correctly. So I screwed in the the two mounting screws and started up the bike after a couple of tempests and it ran sweet for 15 minutes, After lunch I came out agin and started up the bike only to see a huge amount of fuel coming out from above the rocker cover ( I had the fairing back on so I couldn't see where exactly where or if it was fuel ) I switched off and stipped fairing off.
So Im thinking that rail is not seated properly for injectors. Is there a correct procedure ?
2Back to top Go down   Fitting fuel injector Empty Re: Fitting fuel injector on Wed Feb 22, 2017 6:59 pm
BobT
BobT
First of all the K100RS was not made in 1994 the K1100 was out by then.
The fuel would have been coming from somewhere around the fuel rail, the bit the attaches to the top of the injector. There are rubber o rings in there and if the bike has been standing a while, and you have disturbed them, then one of them could be suspect or one of the pipes to that fuel rail could be leaking.
It is very simple to drop the side fairing to see what is happening,
3Back to top Go down   Fitting fuel injector Empty Re: Fitting fuel injector on Wed Feb 22, 2017 8:07 pm
Hi Peter welcome to the forum.
If you put your model and the VIN in your signature line it helps those helping as the model was available for over 20 years with many variants. We can tell from the VIN exactly which one it is.
I have found that a light coating of petroleum jelly will help the injectors seat properly. I always seat each injector into the head then place the fuel rail onto them then replace the clips that hold the injectors to the rail then bolt the rail down, don't rely on bolting the rail down to seat the injectors as it wont always happen.
4Back to top Go down   Fitting fuel injector Empty Re: Fitting fuel injector on Wed Feb 22, 2017 11:03 pm
Hi Peter and welKome to the forum.
.... I also found that the top o ring was had a tear in it .
You need to replace the kits on all injectors. It seems they're getting a little old.
Something like this is what you need
Also, probably a good idea to clean all your injectors while you have them out.
5Back to top Go down   Fitting fuel injector Empty Re: Fitting fuel injector on Thu Feb 23, 2017 5:18 am
If the bike was laid up its also possible and most likely the fuel lines were gone hard and have cracked. You will have been moving them about to get them off the injector rail and on 2 Ks with me that has resulted in them cracking. Replacement is cheap and easy enough but requires the bottom of the airbox being taken out to get the connections on the Fuel Pressure Regulator [FPR].
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
6Back to top Go down   Fitting fuel injector Empty Thanks Bob on Thu Feb 23, 2017 6:07 am
Peterk100rs
Peterk100rs
@BobT wrote:First of all the K100RS was not made in 1994 the K1100 was out by then.
Thanks Bob
You are infact right . I went back and checked the log book and the bike had been previously registered in 1992.
7Back to top Go down   Fitting fuel injector Empty Correct method sounds good . on Thu Feb 23, 2017 6:10 am
Peterk100rs
Peterk100rs
@RicK G wrote:Hi Peter welcome to the forum.
Hi
Thanks for the info . I removed all the injectors this morning and the rail to check for any damage. I did  notice the o rings on all injector where a bit flat and hard so Ive ordered a new set . Fitting the injectors to the block first does make sense and I will used the petroleum jelly too as I know this works well .Thanks for your help .
8Back to top Go down   Fitting fuel injector Empty Moto bins on Thu Feb 23, 2017 7:57 am
Peterk100rs
Peterk100rs
Well after taking some advice last night on here I ordered a seal kit for the Injectors. Haven't fitted it yet but just to say it arrived this morning from Moto bins, thats some service. Now to the shed study
9Back to top Go down   Fitting fuel injector Empty Re: Fitting fuel injector on Thu Feb 23, 2017 10:06 am
Nice looking bike.  I see the previous owner got tired of dealing with cracked exhaust pipes and like myself,  installed an early model K100 exhaust on your bike.
