1Back to top Go down   ABS again, but SUCCESS this time Empty ABS again, but SUCCESS this time on Thu Mar 16, 2017 7:33 am
DeRodster
DeRodster
Hello All,
Having had problems recently with corrosion on the battery neg- cable / terminal and a low battery I ran into the ABS not resetting problem.
Fitted new battery but the damn ABS just wouldn't reset no matter what method I tried.
Got in touch with Tosi in Japan and recommended, before I sent the unit to him, to spray Deoxit on the multi-pin connector under the seat and connect / disconnect the connector a few times.
I then made sure by cleaning it, that the centre pin of the 3 pin connector under the seat was making good metal to metal contact.
I then did the reset 3 or 4 times and what do you know I now have ABS working correctly
Wohoo and just in time for the weekend ride too
Have a GREAT St.Patrick's Day
ABS again, but SUCCESS this time Shamro12
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   ABS again, but SUCCESS this time Empty Re: ABS again, but SUCCESS this time on Thu Mar 16, 2017 8:24 am
Innit great when you have a win and innit great when it saves you a bunch o' money!
Well done!
Thanks for sharing; it may help others out there in K land.
3Back to top Go down   ABS again, but SUCCESS this time Empty Re: ABS again, but SUCCESS this time on Thu Mar 16, 2017 9:05 am
@blaKey wrote:Innit great when you have a win and innit great when it saves you a bunch o' money!
Well done!
Wont be saving him any money........
Being Patricks weekend here the joy must be shared in the usual manner. Shamrock Drinks are on the house and K land is a big place!!!
Nice one Rod.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now91,850 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox
4Back to top Go down   ABS again, but SUCCESS this time Empty Re: ABS again, but SUCCESS this time on Thu Mar 16, 2017 9:11 am
DeRodster
DeRodster
Howrya Olaf,
Now there's a thought
Problem is pay day ain't for a couple of weeks...fella would die of thirst before then
Will you be wearin the green tomorrow !!!!
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
5Back to top Go down   ABS again, but SUCCESS this time Empty Re: ABS again, but SUCCESS this time on Thu Mar 16, 2017 9:50 am
Don't worry Rod, we are a patient lot.
