You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    K1100 center stand on Thu May 11, 2017 10:41 pm
Hello all my K100RS has finally busted her staintune but I have a spare k1100 zorst laying around so in order to fit it does anyone have a spare k1100 centrestand side stand exhaust bracket assy they would like to sell. Strangely enough those that are breaking k1100 tend to need the stand till the grim end. Thanks guys for any assistance I do believe that just the exhaust bracket may be enough to fit to the K100RS stand but as they are notoriously fragile thought it the perfect time to change. Cheers KKlompy
KKlompy
2Back to top Go down    Re: K1100 center stand on Fri May 12, 2017 4:53 am
bugga ...sad to hear klompy
do you have pics that you might share ?
good luck with the fixing ol mate
3Back to top Go down    Re: K1100 center stand on Fri May 12, 2017 5:09 am
The stainless exhaust work gardens like all good stainless does on machinery and so I have a radial crack right round the muffler bit and the nice gold color may indicate the temp range which would have helped the issue. So the bracket that supports the zorst on the TJ center stand point would probs suffice. This is the reason k1100 exhausts brake so often people forget to replace the rubbers.
KKlompy
4Back to top Go down    Re: K1100 center stand on Fri May 12, 2017 9:26 pm
Good luck with it Klompy, youmay also need to replace the exhaust studs as the K1100 has longer studs.
5Back to top Go down    Re: K1100 center stand on Sat May 13, 2017 10:32 pm
@klompy the grey brick wrote:The stainless exhaust work gardens like all good stainless does
I'd love to see one doing the gardening over here, but maybe it's just a magic Oz thing?
