1Back to top Go down   Accelerator cable replacment Empty Accelerator cable replacment on Mon May 22, 2017 3:58 am
Howardz
Howardz
  • So I need to replace my throttle cable new to classic motorcycles and BMW's I have an 86 k100Rt am I going to need to remove my tank to replace it or what would be the best way
2Back to top Go down   Accelerator cable replacment Empty Re: Accelerator cable replacment on Mon May 22, 2017 7:33 am
Tape the new cable to your old cable and pull it gently through if it gets stuck pull it back a bit and try again.
Make sure to get the marks on the throttle assembly under the cover lined up.
3Back to top Go down   Accelerator cable replacment Empty Re: Accelerator cable replacment on Mon May 22, 2017 8:38 am
Howardz
Howardz
Thank you the set up makes it seem a bit harder then it is
4Back to top Go down   Accelerator cable replacment Empty Re: Accelerator cable replacment on Mon May 22, 2017 12:36 pm
It's a fiddly one. Have patience. Getting it located is the easy part. You'll need to remove the lower fairings.... at least the left side. Getting it seated and engaged with the semi circular actuator on the TBs is tricky.
  Accelerator cable replacment Austra12    Fuel:  95 Octane
5Back to top Go down   Accelerator cable replacment Empty Re: Accelerator cable replacment on Tue May 23, 2017 5:43 am
Howardz
Howardz
Alright cool I'll give it a go
