1Back to top Go down   k100 cafe racer running problem Empty k100 cafe racer running problem on Thu May 25, 2017 8:05 am
tyetye
tyetye
HELP.....
ive not long finished my cafe racer project but seem to have a problem.. firstly i need to stay ive changed the air intake and it practicly has no exhaust now. looks good and sounds te bollocks but i have a flat spot mid range.
it rides fine at low revs and goes like a missle when i open the throttle but if i try to hold the throttle mid range, its flat , almost feels like a misfire. the throttle bodys have been balanced and the airflow meter has been adjusted to compersat the K&N air filter, valve clearances are ok, new plugs and leads seem to be good. TPS is working and adjusted correctly.
im at a loose end???????
its not stopping me from enjoying the bike but would like to get to the bottem of the problem.
if someone can also tell me how to add pictures to the thred i will.
thanks.
2Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 8:13 am
Chocolate
Chocolate
Hello!
Try this link
How do you post a picture or a movie?
3Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 8:22 am
When you open a new post text box you'll see 2 picture icons on the left of the fifth group of icons. 'Host an image' and 'Insert an image'.... sounds like you did a good job of your cafe.... you should be able to work it out. If not there's a 'sticky' at the top of the General Discussion forum.
Try advancing the timing by about 4º
  k100 cafe racer running problem Austra12    Fuel:  95 Octane
4Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 8:25 am
What did you change on the intake?
How and why did you adjust the mass airflow sensor?
5Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 8:34 am
tyetye
tyetye
INTAKE.
 ive removed the mass air flow from the airbox and fitted it straight onto what i call the plenom chamber, make an adaptor to take a K&N fitter. the mass air flow meter was adjusted to richen up the fuel at idle, before adjusting the plugs were coming out white.. to lean. now they are a grey/brown colour.
6Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 8:39 am
tyetye
tyetye
k100 cafe racer running problem 20160611
k100 cafe racer running problem 20160612
k100 cafe racer running problem 20160610
k100 cafe racer running problem 20160615
k100 cafe racer running problem 20160613
k100 cafe racer running problem 20160614
k100 cafe racer running problem 20160618
k100 cafe racer running problem 20160616
k100 cafe racer running problem 20160617
k100 cafe racer running problem 20160910
7Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 8:42 am
tyetye
tyetye
k100 cafe racer running problem 20160920
k100 cafe racer running problem 20160917
k100 cafe racer running problem 20160922
k100 cafe racer running problem 20160919
k100 cafe racer running problem 20160921
k100 cafe racer running problem 20160918
k100 cafe racer running problem 20161013
k100 cafe racer running problem 20161014
k100 cafe racer running problem 20161016
k100 cafe racer running problem 20161015
8Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 8:44 am
tyetye
tyetye
k100 cafe racer running problem 20161211
k100 cafe racer running problem 20170210
k100 cafe racer running problem 20170318
k100 cafe racer running problem 20170320
k100 cafe racer running problem 20170317
k100 cafe racer running problem 20170319
k100 cafe racer running problem 20170323
k100 cafe racer running problem 20170321
k100 cafe racer running problem 20170322
k100 cafe racer running problem 20170324
k100 cafe racer running problem 20170325
k100 cafe racer running problem 20170326
9Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 8:59 am
Oh dear! Looks like it might've been an SE in its previous life.... k100 cafe racer running problem 177381
10Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 9:33 am
tyetye
tyetye
What's an SE?????
11Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 9:53 am
SE = Special Edition
Blue/White paint job, white wheels, white on crank and valve covers, painted white side bags and a few other upgraded odds and ends.
How did you adjust the MAF? By spark plug color?
12Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 10:21 am
tyetye
tyetye
Best I could do was vlean new plugs. Run at idle for 10 mins. Pulled the plugs and checked. Then good clean adjust mass with the Alan key . Repeat.  .. Tolk along time to get the colour I wanted. My local garage won't put it on there gas Analyser in case it damage is it
13Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 10:32 am
Damage what? Your bike or the analyzer?
Here's another method:
http://skylands.ibmwr.org/tom/tech/co-setting.html
14Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 11:09 am
tyetye
tyetye
The analyer.
Any way I thought the mass air flow adjuster only controls fuel mixture at idle. After that the flap is moved by air flow from opening the throttle. My problem is the mid range????
15Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 11:42 am
k-rider
k-rider
@tyetye wrote:The analyer.
it does ,the method DUCK linked to works really well , but as you say it only affects the idle mixture, the lack of power in the midrange is probably due to your modification of the intake path and almost completely removing the ehaust, this might be great at WOT , but i belive the engeniers at BMW did a great job choosing a looong intake path , this provides tourqe all the way from bottom to top end
k- rider
16Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Thu May 25, 2017 12:23 pm
A little known feature built into the brick. If you have the engine idle set at at least 1000Rpm press the green starter button if the mixture is correct the idle stays the same or increases just slightly. If the idle drops or increases significantly the mixture is wrong and needs to be adjusted. This method only works on 2V bricks not the 4V ones. A suggestion has also been made that you can use this feature as a boost, not so sure about that one. Rolling Eyes
17Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Sat May 27, 2017 10:35 am
tyetye
tyetye
It's been suggested that I advance the ignition timing by 4 degree.  . I know how the do this by timing the timing plate clockwise but is the any way of checking it? Ie timing light?
18Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Sat May 27, 2017 11:28 am
Yes, you can use a timing light on a K.  But the forks kind of get in the way. I've read of using a mirror but haven't tried that myself.
19Back to top Go down   k100 cafe racer running problem Empty Re: k100 cafe racer running problem on Sat May 27, 2017 1:40 pm
@tyetye wrote:It's been suggested that I advance the ignition timing by 4 degree.  . I know how the do this by timing the timing plate clockwise but is the any way of checking it? Ie timing light?
You can do it by hand. Its nowhere near as critical as timing a points ignition running off a cam. Take a look at this thread.  All the info you need is in post #5 and #7.
