1Back to top Go down    Loose Mirror on Mon Jun 19, 2017 8:41 pm
tagaz
'85 K110RT:
Small issue w left mirror vibration.
Still very much usable.
But would like it as stable as the right side mirror.
I have looked in the Clymer & BMW shop manuals.
As well as searches online.
The parts are listed in the fiche at Max's BMW & elsewhere.
And have only found reference to the mirrors "snapping on & off".
I can see that there has been silicone/caulk added.
Very obvious between the mirror pod and the upper fairing.
I wish to perform repairs as needed to resolve this issue.
Without creating any other issue(s) in the process.
That said, I bow to the wisdom/experience of those who have traveled this path before me.
I am very comfortable working on Airhead/Boxer bikes. And even the "boxer" Porsche's & Subaru's.
But as this "flying brick" is now my primary (only road ready/legal) ride, I want to proceed with the utmost caution.
I really hate it when I break something whilst attempting to fix something.
So, please reply with instructions or links to assist in the removal and diagnosis of the vibrating mirror.
BTW, Evidenced by the scratches on both sides of the bike it is obvious that the bike has been down on both sides.
Doesn't appear to have been too dramatic though.
As always, ITIA for any and all replies.
Troy
2Back to top Go down    Re: Loose Mirror on Mon Jun 19, 2017 10:14 pm
First of all, the K100 vibrates more than the K75 which has a balancer on the output shaft. The mirrors will always be a bit blurry.
Have you done a thorough tuneup? Valve clearance, and throttle body balance can help a lot to get the engine running smoothly. The mirror glass is removed by slamming the mirror body face down on a piece of carpet.
Some have had a bit of improvement by attaching a wheel weight to the back of the glass. I believe they are attached above or below the pivot. I have also heard of people putting a bit of blue Loctite on the pivot ball.
1994 K75S
1992 K100RS
3Back to top Go down    Loose Mirror on Mon Jun 19, 2017 10:49 pm
tagaz
.75 thx 4 d reply.
Yes, all service and maintenance is up to date. And i do mean All.
I do need new skins. Am about to swap the 90/90 V18 off my cafe bike ('91 R100RT Originally)
to the front of the K bike. Rears are totally diff, R = 18 K = 17, or I'd swap the rears too.
I will let y'all know if its "tweaky", "dives" or otherwise behaves badly.
.75 thanks again for taking the time to reply.
But what I need to know is how to remove the mirror pod.
As the mirror is firmly in the pod. It is the pod that is loose. I should have been more precise in my initial description of the issue.
To enable me to diagnose the cause of the vibration, which is more of a wobble that a vibration, and repair,replace or fabricate whatever is necessary to get it to behave the same as the right side mirror.
Troy
Last edited by tagaz on Mon Jun 19, 2017 10:53 pm; edited 1 time in total (Reason for editing : Clarify the issue as being the "pod" & not the mirror)
4Back to top Go down    Re: Loose Mirror on Tue Jun 20, 2017 12:53 am
Those mirrors originally had a rubber backing pad between the pod and fairing, most haven't survived till now. I use the O-rings from a garden hose fitting over the head of the bolt so the pod is firm. I can buy five O-rings in a blister pack so I need 2 packs and 4 extra O-rings for spares. Somewhere in my well organized man cave these O-rings are gathered in groups of 4 well out of my sight.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
5Back to top Go down    Re: Loose Mirror on Tue Jun 20, 2017 1:04 am
^ Clever.
6Back to top Go down    Re: Loose Mirror on Tue Jun 20, 2017 1:16 am
@tagaz wrote:'85 K110RT:
Troy
Are you talking about the mirror pod vibrating or the glass vibrating inside the pod?
I had a loose glass in the pod that vibed a bit. I removed the glass, fitted the cutoff fingertip of a rubber glove over the metal ball and refitted the mirror glass. No more movement.
'87 K100RS/HRD sidecar (1100 motor)sc25
'92 K100RS-16v (Paint it Black)
7Back to top Go down    Re: Loose Mirror on Tue Jun 20, 2017 1:18 am
@RicK G wrote:Those mirrors originally had a rubber backing pad between the pod and fairing, most haven't survived till now. I use the O-rings from a garden hose fitting over the head of the bolt so the pod is firm. I can buy five O-rings in a blister pack so I need 2 packs and 4 extra O-rings for spares. Somewhere in my well organized man cave these O-rings are gathered in groups of 4 well out of my sight.
I've cut a replacement pad from leather,its working fine. I do know it wont last forever but it wont crumble apart like the foam has.
8Back to top Go down    Re: Loose Mirror on Tue Jun 20, 2017 3:55 am
tagaz
Al - 58 thx 4 reply.
How do i remove the pod from the fairing?
Troy
9Back to top Go down    Re: Loose Mirror on Tue Jun 20, 2017 3:58 am
tagaz
Troy
10Back to top Go down    Re: Loose Mirror on Tue Jun 20, 2017 3:11 pm
Troy, the pods are fitted to the fairing with 3 spring clips and are designed to come off if they hit something (like a garage door), so to remove them you need to give the pod a sharp thump from the front.
New spring clips are available.
11Back to top Go down    Re: Loose Mirror on Tue Jun 20, 2017 7:30 pm
Here is a picture of a RS mirror pod (the RTs have the same fixing)
And here's the mounting plate that's fixed to the fairing.
Just thinking of your problem, it may be that the screws holding the mounting plate to the fairing have come loose.
12Back to top Go down    Re: Loose Mirror on Wed Jun 21, 2017 4:05 am
rt fairings use a different fixing paul
I do have pics but not at the office where I am now
its more or less a riveted clip, like jeans about 12- 16mm on the fairing side and a matching castellated clip on the pod x 3
to remove the pods
hit them from the underside , in line with the bottom of the pod ,in an upwards direction
sometimes it is wise to remove the mirror glass first before attempting this , as they could smash as they hit the ground
13Back to top Go down    Re: Loose Mirror on Wed Jun 21, 2017 7:20 am
On the fairing side it's the mounting screws that have specially shaped head
which acts as the male part of the quick mount.
From Ebay:
14Back to top Go down    Re: Loose Mirror on Wed Jun 21, 2017 10:24 am
I have modified my fitting as I found that the mirror pod would not clip in securely on all three posts. By placing another washer between thefairing outside and the post Iwas able to raise the height and therefore all three posts were staying in the sockets of the pod.
1983 K100basic vin 0003960 colour red
1987 K100RT vin 0094685 colour, orange peel, sorry, pearl
15Back to top Go down    Re: Loose Mirror on Wed Jun 21, 2017 10:59 am
cheers inge ..and ainsjac
here's the receiving end of those fairing mounted ""studs " for want of a better word
notice, there is supposed to be a bit of a damper of flexible foam or sum such around the base of the pods ...over the years it has been noticed that the "foam" deteriorates quite significantly ...and not just on the these mirror pods area ....and thus allowing for some slight movement - vibration
like all things rubbery ..they do perish
I solved mine by some neoprene type "bumpers " between the pod and the fairing mount points
as al says o rings could also be a good solution , and as ainsjac says he needed to boost the penetration of the "stud" off the fairing to achieve a solution
just my contribution to trying to solve an issue
hope that helps
16Back to top Go down    Re: Loose Mirror on Wed Jun 21, 2017 11:20 am
For making new "gaskets" between the fairing and pod I've used sole
material for orbital sanders (aviable in different thickness).....handy as
it allready is adesive on side.
17Back to top Go down    Thank all of you on Wed Jun 21, 2017 9:16 pm
tagaz
Charlie, Inge, Ainsjac, Rickg, .75, & Al, thank you for all the great information.
especially Charlie, for clarifying that the pod removal is with an upward tap/wack.
I paused my efforts on the mirror for the moment as we are experiencing dangerously hot weather.
110-120F previous few days, though cooled off a bit today, presently on 109F.
Thx again everyone,
Troy
