1Back to top Go down   Up and running  Empty Up and running on Fri Jun 23, 2017 4:59 pm
timo27
timo27
Ok so engine wise it looks ok ish, replaced the oil/water pump shaft and seals, fuel pump and filter, oil twice and oil filter, my question is how do i know if its running too hot?? i have no temp light ??
2Back to top Go down   Up and running  Empty Re: Up and running on Fri Jun 23, 2017 6:04 pm
@timo27 wrote:my question is how do i know if its running too hot?? i have no temp light ??
Go up to the Profile tab, click on it, scroll down to the box labeled bike* then type into that box your bike's model and year of manufacture—as Olaf has already suggested—so readers will not need to backtrack to find out.
When you assert that you "have no temp light" how have you proved that? Have you tried this test?
https://www.motobrick.com/index.php?topic=8295.0
If your bike's cooling components function correctly, the fan will start before the bike overheats, the temperature will stabilize then the fan will shut off. When the bike overheats, it is then that the warning light in the instrument cluster be will turned on.
Right now you can try to rotate the fan blades with a dowel or screwdriver to determine if the fan is seized or it rotates. That is a basic place to start. If it is seized, the fastest remedy is to replace it. Spal makes an excellent replacement fan that would need mount adjustments for installation. OEM-style replacements that bolt-in are available, and functioning used fans occasionally are found.
1995 K75 73,000 miles
Up and running  Usa-lo10
3Back to top Go down   Up and running  Empty Re: Up and running on Sat Jun 24, 2017 10:11 am
timo27
timo27
Thanks Laitch,
4Back to top Go down   Up and running  Empty Re: Up and running on Sat Jun 24, 2017 2:08 pm
The bike also has a radiator cap that will blow (just like a car) before the engine overheats.
Spal fan:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/fans/fans.htm
5Back to top Go down   Up and running  Empty Re: Up and running on Sun Jun 25, 2017 5:59 am
timo27
timo27
The fan spins free, i followed the process to override the fan temp. thing but nothing happened, i'm going to change the drive oils and sneak it out for a run see what happens, thanks again for your help.
6Back to top Go down   Up and running  Empty Re: Up and running on Sun Jun 25, 2017 11:12 am
The most effective way to know if the OEM fan is working is to jump 12V to its connector.  12V+ to the violet/yellow wire, ground to brown.
If that works then a fan not coming on problem is caused by something else being amiss.
