1Back to top Go down    New member from Portland oregon on Thu Jun 29, 2017 12:28 am
Semlisun
Semlisun
Hello everyone, my name is Simon and a recently picked up a 1988 K100rs. It has 81,000 on the odometer and what looks to be a small oil leak from the back of the engine. Might be a clutch boot or rear main seal.
The only experience I have so far is I rebuilt a 1978 Honda cb750 and but I really like the look of the k100 and when the time was right was able to pick one up for a great deal.
I am planning to replace all the rubber, clutch, rear main seal and all the oils and fluids.
With this I will also do the spline lube.
Any advice will be greatly appreciated.
2Back to top Go down    Re: New member from Portland oregon on Thu Jun 29, 2017 4:23 am
WelKome from another Pacific Northwet member.
I wouldn't replace the rear main seal unless it's leaking. A common source for oil leaks at the rear of the engine is the clutch nut O-ring. Once you take the transmission off to access the clutch you will know what the cause of your oil leak is.
3Back to top Go down    Re: New member from Portland oregon on Thu Jun 29, 2017 11:33 am
Semlisun
Semlisun
Thank you!
That's exactly what I was going to do. Just assess it when I get into it.
