1Back to top Go down   RS or LT Empty RS or LT on Sun Jul 02, 2017 1:13 pm
Davep
Davep
Hi All,
I was making a list of the bits I need as I want to put some LT bars on my RS (Long rides coming). But as I looked it appears I already have an LT dash pad can anyone confirm this? As I looked deeper it seems that the seat may also be LT and not RS original, again, can anyone confirm this? Please forgive the gorilla tape but it rains a bit over here and it started to get a bit soggy!! Many Thanks! Dave
RS or LT Bmw_k110
RS or LT Bmw_k111
RS or LT Bmw_k112
RS or LT Eu-log10BMW K100RS 1983 (Main ride)
Suzuki GSX 750 ET 1979 (Needs work)
Kawasaki Zephyr 750 1992 (Needs hiding)
2Back to top Go down   RS or LT Empty Re: RS or LT on Sun Jul 02, 2017 3:38 pm
That dash pad is same as on my RT and LT.
If you are getting RT/LT bars the heated grip ones differ from non heated grips. If you don't have heated grips you can simply cut the end off the type for heated grips.
You will definitely need
Bars
Clutch cable
Front brake hose from master cylinder down to the centre tube.
I can remember if the throttle cable differs too, just run a quick check.
The wiring and switchgear is all the same so no need for parts, it can be wriggled to fit but make sure all works before you put the tank back. Especially the clutch cut out switch connector to the loom....
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now91,850 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox
3Back to top Go down   RS or LT Empty Re: RS or LT on Sun Jul 02, 2017 5:23 pm
Davep
Davep
That's great!
Thanks for the advice, I want to make sure everything's there before I start!
4Back to top Go down   RS or LT Empty Re: RS or LT on Sun Jul 02, 2017 9:37 pm
You will need all 3 bowden cables plus the brake hose. As Olaf has said the electrical cables are all good for the extra length and having the correct bars for heated grips is important unless you are heading for Syria as it's fairly hot there now.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
5Back to top Go down   RS or LT Empty Re: RS or LT on Mon Jul 03, 2017 2:59 am
With RT bars on your RS your head will be slightly higher and probably in the slipstream off the windshield. It'll be noisier and maybe a little more strain on your neck from the wind. This is normally a concern for RT riders anyway and your RS screen is lower.
1988 K100RT VIN No. 0094680
1989 K100RT VIN No. 0097367 (naked)
1996 K1100RS VIN No. 0451808
RS or LT Austra12 Fuel: 95 Octane
Engine Oil:Nulon Full Synthetic 15W50
Gear Box Oil: Nulon Synthetic 75W90
6Back to top Go down   RS or LT Empty Re: RS or LT on Mon Jul 03, 2017 5:37 am
Forgot too about the 'choke' cable.
7Back to top Go down   RS or LT Empty Re: RS or LT on Mon Jul 03, 2017 2:07 pm
Corkboy
Corkboy
I swapped the RS bars on my 100RS for a set of "C" bars and didn't need to replace any hoses or cables. it was a straight swap.
Can't remember about heated grips, but seem to remember I had bar end weights.
Something to consider if money/time is tight.
'87 K100RS 0140995 (Gone)
'97 K1100LT 0188024 (Gone)
'08 Transalp 700
