1Back to top Go down   Petrol tank and fuel pump Empty Petrol tank and fuel pump on Mon Jul 03, 2017 11:54 am
timo27
timo27
Hi, with ref. to my 1984 k100, one thing thats been on my mind is that of the wiring of the fuel pump in the tank covered in fuel?? do they ever blow up.
2Back to top Go down   Petrol tank and fuel pump Empty Re: Petrol tank and fuel pump on Mon Jul 03, 2017 12:00 pm
You mean like this?
Petrol tank and fuel pump 2Q==
3Back to top Go down   Petrol tank and fuel pump Empty Re: Petrol tank and fuel pump on Mon Jul 03, 2017 12:02 pm
timo27
timo27
Yes you got it .......
4Back to top Go down   Petrol tank and fuel pump Empty Re: Petrol tank and fuel pump on Mon Jul 03, 2017 12:14 pm
Never heard of it happening and may cars use a similar arrangement. You need an arc short aross a gap, like a spark plug, in fuel vapour, to get a big bang. So always disconnect battery and power off when working in tank....even if you pull the tank plug connector.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
5Back to top Go down   Petrol tank and fuel pump Empty Re: Petrol tank and fuel pump on Mon Jul 03, 2017 8:38 pm
That's why you should always wear ear plugs.
6Back to top Go down   Petrol tank and fuel pump Empty Re: Petrol tank and fuel pump on Mon Jul 03, 2017 8:38 pm
I have never heard of it happening. To ignite petrol in liquid form is almost impossible and even the vapour needs to have the air vapour mix right to ignite. I think these figures are right but I will stand corrected. If the mix is less than about 3 to 1 or over 18 to 1 then it wont ignite. That's why a lean mix wont ignite in an engine and a flooded engine wont start. Usually the pump and gauge are below the fuel level and also the air to vapour mix above the fuel level is like a flooded engine.
Almost since the advent of electric fuel gauges there has been 12v connections inside the tank and those senders would be far more likely to develop a fault where arcing would occur than a fuel pump.
7Back to top Go down   Petrol tank and fuel pump Empty Re: Petrol tank and fuel pump on Tue Jul 04, 2017 4:53 am
I think the worst that could happen is if you had a leaking fuel line and fuel got onto a hot engine. That might set your pants on fire affraid
I think if I was the guy second from the right, I'd be moving off pretty quick.
Petrol tank and fuel pump 183347
  Petrol tank and fuel pump Austra12    Fuel:  95 Octane
