1Back to top Go down   Valve stem oil seal tool Empty Valve stem oil seal tool on Mon Jul 03, 2017 3:43 pm
aladin1
aladin1
I'm in the process of renovating my K100 engine and need the tool to fit new valve stem oil seals ( BMW 11 1 940). I can't find anywhere selling them after Googling for UK suppliers. Can anyone direct me towards a source or an alternative method?
2Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool on Mon Jul 03, 2017 8:28 pm
I've always used a socket or a piece of tube of the correct diameter. Just had a look at my Haynes Manual and they show a socket in section 2.18. However AGA tools have a set for $990.00. Valve stem oil seal tool 25650
Regards Martin
3Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool on Mon Jul 03, 2017 8:38 pm
I used this tool set to do mine. When I was done I sold them for $10. I greased up the valve stem with assembly lube to help the seal slide down the shaft and lube the guide. Worked a treat.
http://www.ebay.com/itm/Valve-Stem-Seal-Seating-Remover-Tools-Set-Installer-Oil-Plier-Car-Garage-Tool-/122511503658?epid=1354135908&hash=item1c8641312a:g:23QAAOSwuMZZI-Yl
4Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool on Mon Jul 03, 2017 9:12 pm
@Point-Seven-five wrote:I used this tool set to do mine. When I was done I sold them for $10. I greased up the valve stem with assembly lube to help the seal slide down the shaft and lube the guide. Worked a treat.
That is fairly much what I use except that mine is a lot older and has a pressed metal case that weighs 2 ton Very Happy
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
5Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool on Tue Jul 04, 2017 4:06 am
aladin1
aladin1
Thanks for the advice guys.....I think I'll pass on the $990.00 AGA set Martin and have a look on fleabay for a cheapo set like Point.Seven.Five used, and I'll check out the socket method.Valve stem oil seal tool 112350
6Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool on Tue Jul 04, 2017 2:36 pm
mike d
If you are a UK BMW Club member, we have the seal tool in the Tool Hire facility.
Mike
7Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool on Tue Jul 04, 2017 6:06 pm
aladin1
aladin1
Thanks Mike......I have managed to fit the seals using a short section of tube. Fingers crossed that all is OK.
