1Back to top Go down   1987 K100RT cafe Empty 1987 K100RT cafe Sat Jul 08, 2017 10:04 am
Mikewills
Mikewills
I was going to hold off starting a build thread but I can't contain myself as I start the slow progress of customizing my recently purchased bike.
It has all broken fairings and a dead battery, have no idea how long it's been since it was last moving along the road!
2Back to top Go down   1987 K100RT cafe Empty Re: 1987 K100RT cafe Sat Jul 08, 2017 10:12 am
Mikewills
Mikewills
So a couple of poor quality images off my phone of the progress so far:
1987 K100RT cafe 65662451-7C0C-4FFA-BD61-71E97FDFE1B2
1987 K100RT cafe 3A6F5813-CC96-4828-8E91-F795739D9DB2
1987 K100RT cafe 386C0BE8-0044-42AF-B475-A3ABBAEB1920
1987 K100RT cafe 86DB3BD5-8219-4AF4-8B42-916163F1F8BE
1987 K100RT cafe 3A8C3622-3690-424F-A181-8AA3ABA62120
1987 K100RT cafe 582F6FBF-AED3-4B9E-9D9B-FF6911D2BF66
1987 K100RT cafe 11F50EBB-240C-4F7E-97B6-52F83E1396FD
1987 K100RT cafe 7264F7F8-855A-4050-8A2A-0782060692BF
1987 K100RT cafe 026BAB57-B014-4806-AF75-DA1293C96366
1987 K100RT cafe CDAE1660-8D5C-4E60-8EF6-DB13102E4B7B
1987 K100RT cafe B85EC8B8-0542-4A49-9E22-E36CDBE7F4AE
3Back to top Go down   1987 K100RT cafe Empty Re: 1987 K100RT cafe Sat Jul 08, 2017 10:19 am
Mikewills
Mikewills
So, purchased a K1200 rear wheel for it, painted both wheels and fitted them today so I can roll it back to my house as it's been in storage the last 2 months at a mates house.
I've also had the clip ons and new headlight turn up.
I know the front brakes and front forks look a mess at the moment but they'll be done as the project moves along.
I have put a new battery in it and it is also running now which obviously makes me happy
Thanks for looking, and thanks in advance for advice I'll be taking on board as I go along this build
4Back to top Go down   1987 K100RT cafe Empty Re: 1987 K100RT cafe Sat Jul 08, 2017 10:22 am
Mikewills
Mikewills
1987 K100RT cafe CE2AA21A-E7B2-4B39-A742-18155BBF55A9
1987 K100RT cafe FC9CEC5E-CC98-45BD-87E2-A3F930036B3F
5Back to top Go down   1987 K100RT cafe Empty Wire Wheels Fri Aug 11, 2017 2:35 am
Kafflut
Kafflut
IMO there isn't an "easy" way to put wire wheels on the K100. I've just converted mine - just fitted the wheels & brakes; brake lines not yet done and then it still has to be tested. But I thought I'd share some ideas that may be useful
The 1150 G/S wheel I bought fitted straight on. I was able to use the regular K100 spindle. I made spacers to get it to run so there's no fouling with the forks and used oil seals on both sides to keep some dirt out. Disks were laser cut using  a 1150 G/S disk as a template. I made the mounting bolts & spacers. I could not find suitable wavy washers, so it rattles a bit, but not much.
The K100 calipers are okay. I made adapter plates - the 1150 G/S disk is bigger than the K100.
The rear wheel was much more complicated. I obtained a used 1150 G/S Brembo calipers. The K100 calipers would foul with the spokes no matter how you position it. It is possible to use the old K100 disk, but then the rear wheel is positioned to far to the left. You need a bigger than standard 1150 G/S disk. Because of the diameter of the bevel drive housing the calipers mount in such a way that the brake pads don't fully engage with the smaller 1150 G/S disk. So I had one laser cut, 306mm diameter.
The calipers also required adapter plates. That was  a trial and error process. And I had to surface grind the mounting face of the calipers.
I'll post images at some stage and I have .dxf files for the rear disk & adapter plates if someone wants.
http://bmwk100k75.weebly.com/
6Back to top Go down   1987 K100RT cafe Empty Spoked wheels Fri Aug 11, 2017 4:25 am
rbroen07
rbroen07
Maybe you have already seen it, but check this out:
https://www.youtube.com/watch?v=Ua2OaaCFhkk
7Back to top Go down   1987 K100RT cafe Empty Re: 1987 K100RT cafe Tue Aug 15, 2017 7:03 am
Kafflut
Kafflut
rbroen07 wrote:Maybe you have already seen it, but check this out:
Thank you rb
Way beyond my budget Very Happy
8Back to top Go down   1987 K100RT cafe Empty K100 Rear Calipers Tue Aug 15, 2017 7:10 am
Kafflut
Kafflut
I've decided to make a change. I could not use the rear brake calipers because
a) The inside of the unit protrudes too far into the spokes.
b) The bottom of the calipers foul with the spoked wheel hub
However, having fitted a bigger disk, b) is no longer a factor. So I looked at a) again. I can use the K100 calipers if I remove a smidgen from the casing of the calipers in places.
I did removed some material from the top of the unit - all is working fine except the piston housing needs to be filed, just the upper edge of the circular housing.
Does anybody know the wall thickness?
I could open it up and measure, but if someone has an open one or link me to a cross section drawing of the unit, it would save me that
9Back to top Go down   1987 K100RT cafe Empty Re: 1987 K100RT cafe Tue Aug 15, 2017 7:33 am
rbroen07
rbroen07
Kafflut wrote:I've decided to make a change. I could not use the rear brake calipers because
Pictures would be nice Smile
10Back to top Go down   1987 K100RT cafe Empty Re: 1987 K100RT cafe Wed Aug 16, 2017 1:05 am
Kafflut
Kafflut
Thanks for the suggestion, rbroen
I'm going to take some photos and post an article on my web site
I'll PM you when I've done it - probably a week or so from now
11Back to top Go down   1987 K100RT cafe Empty Wire Wheels Fri Aug 25, 2017 2:24 am
Kafflut
Kafflut
I saved some images
http://bmwk100k75.weebly.com/wire-wheels.html
I'll ad text later. It's trial and error work and I'll update the site from time to time
