1Back to top Go down   Wanted K100LT Front Wheel a rim  Empty Wanted K100LT Front Wheel a rim on Fri Jul 14, 2017 9:29 am
Bunyak100
Bunyak100
My front rim is damaged and believe not really repairable and would like to source a good used replacement. It is the Y type original wheel rim
2Back to top Go down   Wanted K100LT Front Wheel a rim  Empty Re: Wanted K100LT Front Wheel a rim on Fri Jul 14, 2017 9:35 am
Wheel casting changed slightly, the rim part on early ones is concave, later ones flat. My LT has the alter ones and the RT the earlier ones. Interchangeable but if you are perfectionist be careful as the difference is noticeable if you look. The dates suggest both types are used on the LT. Casting date is stamped on them and that's the give away.
3Back to top Go down   Wanted K100LT Front Wheel a rim  Empty Re: Wanted K100LT Front Wheel a rim on Fri Jul 14, 2017 8:22 pm
How bad is the damage?  If it's a few flat spots then they are repairable despite what BMW will say. I've done a few now and they have all come out well.
4Back to top Go down   Wanted K100LT Front Wheel a rim  Empty Re: Wanted K100LT Front Wheel a rim on Sat Jul 15, 2017 2:01 am
Bunyak100
Bunyak100
Thanks I will check an see exactly what I have
The rim using a dial gauge is running out 10mm on the side of the rim itappears to have a twist
5Back to top Go down   Wanted K100LT Front Wheel a rim  Empty Re: Wanted K100LT Front Wheel a rim on Sat Jul 15, 2017 3:23 am
Not much you can do about that without some very fancy machinery.
6Back to top Go down   Wanted K100LT Front Wheel a rim  Empty Re: Wanted K100LT Front Wheel a rim on Sat Jul 15, 2017 6:46 am
I bought a rear wheel off eBay in April. I was looking at refurbing the one that was on the RT but I ended up with a replacement that cost me €57 landed. It came with a BT45 on it that looked like it had only done 1,000 miles and 3714 manufacture date. My main reason was to not have the K off road but the replacement was good enough to leave as is. It will be worn out by end of August.
The 'old wheel' is now a spare wheel with a good tyre on it.
The 'new' wheel was the later casting but I have a spare front to match it along with spare disc bolts.
Plenty of odd wheels out there to avoid expensive repairs.
