1Back to top Go down    Interesting drive shaft video on Mon Jul 17, 2017 1:54 pm
Somebody posted this on the K11 OG forum. Interesting if you're a gearhead and at the end it demonstrates the importance of proper U-joint phasing on the 4V paralever Ks.
https://www.youtube.com/watch?v=gmV4qwLfOMY
2Back to top Go down    Re: Interesting drive shaft video on Mon Jul 17, 2017 8:35 pm
Also shows how BMW made a monumental mistake in having only one uni joint on the monolever shaft and why it hammers the splines because the shaft is changing rotational speed while the pinion shaft is staying at a constant speed.
The only saving grace is the free play in the gearbox at the engagement dogs otherwise the shaft would tear itself to bits within a few thousand miles if that long..
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
3Back to top Go down    Re: Interesting drive shaft video on Mon Jul 17, 2017 8:50 pm
JMHO but I think what causes the majority of the spline wear is the rear splines sliding against each other under load when you accelerate. That's when there's the most power being transmitted and the mono splines slide against each other when the monolever FD gets "jacked."
Pretty sure that''s why the splines at both ends of the para drive shaft are held in place by clips - so they can't slide more than a very small amount.
4Back to top Go down    Re: Interesting drive shaft video on Mon Jul 17, 2017 9:07 pm
This is what happens when the hammering takes place and you are right that it would happen under acceleration
