1Back to top Go down    Water pump warning on Tue Jul 25, 2017 11:49 pm
GF Wollongong
GF Wollongong
If you own an early K100 be careful with the water pump. Removing the shaft nut will very likely result in shearing the shaft. This has happened twice now - both 1984s. Probably because corrosion sets in.
Not sure if it is better to leave "well enough alone" - might well break at the side of the road.
Which brings me to:
Anyone got a water pump to suit?
Regards
Guy
2Back to top Go down    Re: Water pump warning on Wed Jul 26, 2017 6:30 am
That's a guaranteed break point, it WILL break. Either fix with a new shaft or leave alone.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 87,980 miles
1983 K100RS 0011175 Fricka 29,000 miles Damn K Pox
3Back to top Go down    Re: Water pump warning on Mon Jul 31, 2017 7:37 am
GF Wollongong
GF Wollongong
Errr .... leave it alone.
Maybe heat and freeze ... if the other seals need replacing. Recently saw comment that they seals should be done about every 8 years. My two were 34 years old. S'pose it's got to be expected.
Nyloc nut will obviously need replacing
G
4Back to top Go down    Re: Water pump warning on Mon Jul 31, 2017 2:52 pm
That wasn't from a dealer by any chance, was it?
1994 K75S
1992 K100RS
5Back to top Go down    Re: Water pump warning on Wed Aug 02, 2017 9:12 am
GF Wollongong
GF Wollongong
No ... not a dealer (I assume)
Private owner, enthusiast and obsessive.
Am greatly appreciative to fellow member sending me a water pump.
Just need the output shaft and a motobins delivery and then back together.
Guy
