1Back to top Go down    Output shaft Rivet Play on Wed Jul 26, 2017 5:53 am
GF Wollongong
GF Wollongong
Have replaced the anti-backlash spring and before I return the item to the bike...
How much movement or play is acceptable in the output shaft? I have the 6 rivet model and there is about 2mm side to side movement between the thinner black gear and the larger silver metal gear.
Is this okay. Is this consistent with original? If not can I just re-compress the rivets using a punch?
Failing all that ... anyone got a 12 rivet output shaft to fit a K100RT 1984
I have other parts and a barter may be possible
Regards
Guy
2Back to top Go down    Re: Output shaft Rivet Play on Wed Jul 26, 2017 6:43 am
JR_K100RS
JR_K100RS
I'd say zero play Guy , not sure if you could hit the rivets , at best this would only be a temp solution , I replaced mine with the 12 rivet unit 6 years ago
John Re
Melbourne Australia
3Back to top Go down    Re: Output shaft Rivet Play on Wed Jul 26, 2017 9:07 am
ZERO absolutely zero, with any play they rattle like 2 skeletons having a fuck in a tin bucket.
One member did play about with replacing the rivets with bolts but there have not been any results from him.
The 12 rivet shaft can be found from about mid 1990 engines and all 16v engines.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
4Back to top Go down    Re: Output shaft Rivet Play on Wed Jul 26, 2017 9:55 am
GF Wollongong
GF Wollongong
Gloves off on the profanity front, Rick! And we've been holding back all these years.
NO MORE
And just in case: Are you in the market for a winnebago? ... with all the accoutrements
https://www.youtube.com/watch?v=zSWUWPx2VeQ
Okay, will hunt down a 12 rivet output shaft
Was getting the rattle... assumed the spring but maybe the rivets!
Thanks for the reply
Guy
5Back to top Go down    Re: Output shaft Rivet Play on Wed Jul 26, 2017 10:46 am
@GF Wollongong wrote: I have the 6 rivet model and there is about 2mm side to side movement between the thinner black gear and the larger silver metal gear.
Loose rivets won't result in play between the gears, then something else must
be worn......depending on which direction the play is.
Loose rivets will result play between the larger gear and the big alu drum.
6Back to top Go down    Re: Output shaft Rivet Play on Fri Jul 28, 2017 2:01 pm
Albyalbatross1
Albyalbatross1
@RicK G wrote:ZERO absolutely zero, with any play they rattle like 2 skeletons having a fuck in a tin bucket.
Hi Rick.. I did mess about and completed the replacement. The replacement output shaft has been running very well in Charlies Gerty!!!
84 K100 RS..Love this bike..
Most of the time anyways..
7Back to top Go down    Re: Output shaft Rivet Play on Fri Jul 28, 2017 4:33 pm
Hi Alby I didn't realize you had put it in Charlie's heap, he'll give it a good work out Laughing
8Back to top Go down    Re: Output shaft Rivet Play on Sat Jul 29, 2017 12:57 am
when we did the change to the output shaft
I noticed wear of the large gears , not quite sharks toothed but certainly lost some meat in the gear teeth profile
I guess from rattling for so long
I could imagine that any other gear mating to the either of these would also be a bit rattly
but I guess that the auxiliary shaft driving the alternator -sprag clutch etc only works in one direction during normal running
Getry is now rattling atldle
so another pull down will be in the planning stages , and hope to find another damper section with 12 rivets this time and new damper rubbers
9Back to top Go down    Re: Output shaft Rivet Play on Mon Jul 31, 2017 1:27 pm
GF Wollongong
GF Wollongong
Okay everyone
So that's two 12 rivet output shafts
In anticipation...
Guy
