Trapper
Trapper
How to remove a Pushrod oil seal in a K1 Img_2014
Anyone know how the pushrod seal is removed in a K1? Something tells me it's not held in by the circlip as that appears to be holding in the bearing behind it. Could the seal just be seated into the core of the bearing???
K1 Red & Yellow 1990 111.000 Kms & BMW K1 Red & Yellow 1991 22.000 Kms
 How to remove a Pushrod oil seal in a K1 Ir-log10
The seal is pressed into the shaft, use a slide hammer with a expandable collet or a hook.
Trapper
Trapper
Excellent advice - thank you so much.
Trapper
Onya Inge! Very Happy
