1Back to top Go down   Oil pressure light Empty Oil pressure light Fri Aug 25, 2017 1:46 am
timo27
timo27
!984 k100, Hi all, my oil pressure lamp has stopped coming on, could this have anything to do with inadvertently blocking that small hole on the engine face when putting the pump back on?? ie always pressured up?
2Back to top Go down   Oil pressure light Empty Re: Oil pressure light Fri Aug 25, 2017 2:38 am
timo27 wrote:. . . my oil pressure lamp has stopped coming on . . .
Check the connection to the oil pressure switch and the switch itself—#12 in the attached diagram—before going further.
Oil pressure light B0000110
3Back to top Go down   Oil pressure light Empty Re: Oil pressure light Fri Aug 25, 2017 4:34 am
Check the bulb is functioning and not blown.
Regards Martin
4Back to top Go down   Oil pressure light Empty Re: Oil pressure light Fri Aug 25, 2017 7:16 am
I'm with Laitch - that connector is just in the right place to catch all the sh!te from under the engine, corrode up and break the wire.
5Back to top Go down   Oil pressure light Empty Re: Oil pressure light Fri Aug 25, 2017 8:51 am
Easy test: disconnect the wire/connector at the switch and ground it.
If your oil lamp now function, the switch is the problem.
If not, the problem is the bulb or wiring.
6Back to top Go down   Oil pressure light Empty Re: Oil pressure light Fri Aug 25, 2017 9:11 am
Oil pressure light 112350
7Back to top Go down   Oil pressure light Empty Re: Oil pressure light Fri Aug 25, 2017 12:41 pm
timo27
timo27
Thanks you guys its the bulb
8Back to top Go down   Oil pressure light Empty Re: Oil pressure light Sat Aug 26, 2017 10:03 am
Corkboy
Corkboy
timo27 wrote:Thanks you guys its the bulb
While you're in there, maybe take the opportunity to go LED? One of the guys here (Duck IIRC) was selling kits.
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
