1Back to top Go down    productive day on Wed Aug 30, 2017 3:44 pm
Flash of the gap
Flash of the gap
I tackled a few problems on the k100 today, took off the tank to reroute the throttle cable as she is running high, about 1500rpms when idleing, not an air problem, just cable not snapping back as it should, in the process i fixed my two brake switches which were kaput, the old fashioned way electrical tape and stanley blade, no fancy soldering, both working perfect , well for the time being, which in turn knocked off the red light above the neutral,
still have green neutral light on permenantly Crying or Very sad, but will get to it , also took the clocks apart to try and fix the gear position and time clock , no luck, hard to believe all the bulb in the clocks are still working after 33years, if any one has a knackered set off clocks to unload , just want the digital time clock out of em ans the gear positioning thinghy,
mechanical genius me Laughing
bmw k100rs, 0010723 / 31000 mls
2Back to top Go down    Re: productive day on Wed Aug 30, 2017 4:04 pm
Tony - google digital clock on the forum Search (Portal page) - someone has found a cheap standard electronic replacement that is an easy fix.
Also lots of guys have done LED replacement of Bulbs.
Neutral light could be the Gear position sensor a bit of a bummer to get at behind the swing arm.
88....May contain nuts!
3Back to top Go down    Re: productive day on Wed Aug 30, 2017 4:27 pm
Flash of the gap
Flash of the gap
cheers will do, thanks for that
4Back to top Go down    Re: productive day on Wed Aug 30, 2017 4:27 pm
Flash of the gap
Flash of the gap
5Back to top Go down    Re: productive day on Wed Aug 30, 2017 5:04 pm
Not a just a bit of a bummer to get at - I'd say, impossible to get at with the swing arm in place. The only way to get to the GPI sensor is to remove the swing arm (not that hard to do, providing things unscrew like they are meant to)...and while you're in there, inspect your drive shaft and give them thar splines a good greasing with some moly.
The following link may help you determine where your problem lies: real easy to test the if the LCD is reading correctly and fairly simple to test the output of the GPI sensor.
http://www.k100-forum.com/t10495-gear-indicator-board-for-1985-k100rt-instruments#124102
Paul
"Gretel" K100LT 1989 (Silver Grey) (VIN 0177324 Engine No. 104EA 2789 2211) - 4th+ owner. September 2015 (58,500miles and counting....). Cat C Insurancewrite-off rebuild Feb 17
"Donor" K100LT 1990 (Red) (VIN 0178091 Engine No. 4489 2024) - 6th & final owner (crash write-off now donor bike). June 2012 (73,000 miles) to November 2013 (89,500 miles)
