1Back to top Go down   water pump leaks with new seal Empty water pump leaks with new seal on Fri Sep 01, 2017 8:52 pm
KiwiK100
KiwiK100
Hi all, So I have just replaced the seal in the oil/water pump and after leaving it a week, filled it with fluids and hit the starter. Feck Sad  A steady rapid drip at the bottom of the pump from the weep hole. I have done this task on another of my K's and no problem however in this case there was considerable pitting on the driven gear shaft which I cleaned up with 1000 wet and dry however I suspect this is where the leak is now generating from. Would the wise ones agree or is there something I missed. The install of the new seal went perfectly and I feel this was done well so the problem is elsewhere but who knows.
Thanks for your help
Current rides:
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 167,000km
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles.
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grand dads ride
2Back to top Go down   water pump leaks with new seal Empty Re: water pump leaks with new seal on Fri Sep 01, 2017 8:58 pm
That usually means the ceramic seal has been cracked on installation DAMHIK
3Back to top Go down   water pump leaks with new seal Empty Re: water pump leaks with new seal on Fri Sep 01, 2017 9:20 pm
KiwiK100
KiwiK100
Hey Rick, thanks for the prompt reply. Well that would be a right PITA if that's the case although considerably cheaper than a new driven gear. Will a badly worn shaft leak? To be honest the new seal went in really nicely and the only way to see if it is cracked is to destroy it removing it.
The task of replacing the seal was undertaken as there was a slight leak of water from the weep hole in the first place
Current rides:
The family history:
4Back to top Go down   water pump leaks with new seal Empty Re: water pump leaks with new seal on Fri Sep 01, 2017 10:53 pm
KiwiK100
KiwiK100
Hey Rick, here's un update. I pulled and dismantled the pump and close inspection has shown that the ceramic seal had not been driven all the way so had not bedded fully. Don't know how I missed it, and hopefully no damage. I will reinstall and allow 3bond to cure overnight before replacing fluids and another test.
Current rides:
The family history:
5Back to top Go down   water pump leaks with new seal Empty Re: water pump leaks with new seal on Sat Sep 02, 2017 12:38 am
If the seal wasn't in all the way then when you tighten the bolt for the impeller it can crack that seal. It's not uncommon to crack a seal I've done it quite a few times over the years. The tradesman I had in my first year apprenticeship said "would you hit grandma's fine china with that F#@*^@ hammer then don't hit that seal with it".
I haven't come across a shaft that leaks between the seal and shaft but not saying it cant do it and if you can feel a groove with your fingernail then the seal will probably leak but that only applies to the oil side of the shaft.
6Back to top Go down   water pump leaks with new seal Empty Re: water pump leaks with new seal on Sat Sep 02, 2017 12:47 am
KiwiK100
KiwiK100
Thanks Rick for the advice. It's all back together now so will run it in the morning and see what happens...
I realise now what I did. I used the washer and impeller bolt method to draw the shaft through the seal but you cannot draw it all the way without using larger inside diameter washers to allow the impeller spacer to pull up with the shaft. I merely turned the pump over and gave the oil side of the shaft a gentle tap to set the gear flush with the casing. Of course in doing that I moved the seal out the same amount and didn't check it. Duh!
Current rides:
The family history:
7Back to top Go down   water pump leaks with new seal Empty Re: water pump leaks with new seal on Sat Sep 02, 2017 3:42 am
@KiwiK100 wrote:Hey Rick, here's un update. I pulled and dismantled the pump and close inspection has shown that the ceramic seal had not been driven all the way so had not bedded fully. Don't know how I missed it, and hopefully no damage. I will reinstall and allow 3bond to cure overnight before replacing fluids and another test.
good move
good luck !
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%Owater pump leaks with new seal Au-log10
8Back to top Go down   water pump leaks with new seal Empty Re: water pump leaks with new seal on Sun Sep 03, 2017 3:21 am
KiwiK100
KiwiK100
Out for a 100km ride this arvo and initially though I still had a wee leak until I realised there was coolant trapped in no mans land within the seal cavity. Once that was out she dried up and is now tight and dry! Thanks again Rick for your suggestions
Current rides:
The family history:
9Back to top Go down   water pump leaks with new seal Empty Re: water pump leaks with new seal on Sun Sep 03, 2017 3:47 am
water pump leaks with new seal 112350
