1Back to top Go down   Seat Refurb Empty Seat Refurb on Sat Sep 02, 2017 1:53 am
floyd
floyd
So I guess this is why they changed to plastic post 85...
Seat Refurb Img_2010
Seat Refurb Img_2011
2Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sat Sep 02, 2017 3:43 am
floyd
floyd
Change of tac.
Going to acquire a post 85 tail section (which I reckon looks better) and then attach the seat foam from my pre 85 seat to a post 85 plastic seat pan I have, then recover it.
All this while watching the Scientology episode of South Park. Happy Days. lol!
3Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sat Sep 02, 2017 3:48 am
Seat Refurb 112350
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OSeat Refurb Au-log10
4Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sat Sep 02, 2017 4:10 am
floyd
floyd
Anyone got a part number for what goes in the red circles? The one at the top right obviously takes the rear hinge part, but Im thinking all three holes take rubber bungs of some sort. The parts fiche im looking at is unclear.
Seat Refurb Seat_p10
5Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sat Sep 02, 2017 4:30 am
the one at top right is the rear hinge mounting point , but needs a bung in there as well if you don't want to wear the metal parts
yes the other two need a blind bung about 5mm thick x 12 mm ?
standard " 6 mm cage nuts " as used in rack equipment are used for most of the fixings to the seat ..and many other frame places
Seat Refurb 20170911
6Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sat Sep 02, 2017 6:17 am
floyd
floyd
Thanks Charlie. Added them to an order from motorworks Ive been making as they are about the same cost as theyd be at clarke rubber etc, and I already needed stuff from motorworks....Like a 4.5x18" rear wheel Winkyeehaw
7Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sat Sep 02, 2017 6:18 pm
Floyd good video on how to reupholster K100 seat
https://www.youtube.com/watch?v=XZoq_D2kAZA
I did mine not long ago.
8Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sun Sep 17, 2017 3:50 am
floyd
floyd
Mission accomplished...Old seat foam modified ans fitted to a post 1985 plastic seat pan. New foam, vinyl, stainless bolts and captive nuts, rubber bumpers.
Seat Refurb Img_2013
Went with pop rivets and made some spreader plates out of HDPE garden irrigation pipe.
Seat Refurb Img_2012
9Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sun Sep 17, 2017 3:58 am
Looks good, did you change the profile at all or just left it OEM.
10Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Sun Sep 17, 2017 5:51 am
great work Floyd ..
looks comfy
11Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Tue Sep 19, 2017 6:27 am
floyd
floyd
And after all that....
Doesn't bloody fit!!
Seat Refurb Img_2014
12Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Tue Sep 19, 2017 6:53 am
Seat Refurb 44271
well it kinda does Floyd
perhaps just a pad between tank and seat ...and call it designed nut crusher protection
giggles
great effort so far
13Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Tue Sep 19, 2017 6:59 am
Garyk100
Garyk100
Looks good Floyd, I have the same problem with the motoco seat, and the gunfighter seat, might not look right on your machine but I made a lambs wool cover to fit, hides any gaps
The early bird catches the worm, but the second mouse gets the cheese
1991 K100rs16v
1993 K1100LT
14Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Tue Sep 19, 2017 12:34 pm
Floyd I've never had a good look at the early seat mount set up on the Brick. Does yours have the plate with the mounting bolt? If so would it be possible to pack the front mounts out and slot or redrill the rear mounting plate? This might move your tank back enough to fix or partially fix your problem. You also might be able to crib the ducktail and seat mounts forward.
15Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Tue Sep 26, 2017 2:20 am
floyd
floyd
After a good clean up with my new 18v drill and some brass brushes, and a can of 'rust converter' paint. Now for it to be reunited with its original foam (plus some new) and a new coat of marine vinyl.. Ah the joys of doing the same job twice - same same but different.
Seat Refurb Img_2015
Id fix the rust holes if I had a welder, but they will not be a problem...All the nuts are fine too, which is a bonus.
16Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Tue Sep 26, 2017 2:35 am
floyd
floyd
@MartinW wrote:Floyd I've never had a good look at the early seat mount set up on the Brick. Does yours have the plate with the mounting bolt? If so would it be possible to pack the front mounts out and slot or redrill the rear mounting plate? This might move your tank back enough to fix or partially fix your problem. You also might be able to crib the ducktail and seat mounts forward.
To much mucking around in the end i reckon Martin, which is most unfortunate indeed. Anyways, on with the next plan! Ill get this beast back on these SE QLD roads again one day Im sure!
17Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Mon Oct 30, 2017 4:26 am
floyd
floyd
So, after taking the long way round...Ive now got my original seat and tail unit back on, only this time with fresh foam and vinyl Seat Refurb 212902
Seat Refurb K100_210
18Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Mon Oct 30, 2017 5:19 am
Seat Refurb 112350
doing a rock hard rs seat conversion also Floyd ..
do you have pics of your process ?
19Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Mon Oct 30, 2017 9:32 am
Not to hijack this thread, but where did you get those turn signals? With the discontinuance of glass and turn lenses for the RS, there are many who would be interested in how you made them work on your bike.
20Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Mon Oct 30, 2017 4:13 pm
floyd
floyd
@Point-Seven-five wrote:Not to hijack this thread, but where did you get those turn signals? With the discontinuance of glass and turn lenses for the RS, there are many who would be interested in how you made them work on your bike.
ebay linkThey are readily available on ebay mate Wink
21Back to top Go down   Seat Refurb Empty Re: Seat Refurb on Mon Oct 30, 2017 4:49 pm
@floyd wrote:And after all that....
same here Floyd ,
just finished covering my comfort seat which came from Ol' Blue ( 89' k100LT ) and it has a bit of airflow in the front section . It now rest on Smurfette ( K1100RS) and still comfy as .Seat Refurb Img_8316
1987 K100RT Ex- police
1989 K100LT Ol' Blue and "Kart" the Kamper trailer. now KAPUT .
1993 K1100RS 0194321 Colour #690 Silk Blue aka" Smurfette"
Seat Refurb 10_x_110
