1Back to top Go down   Throttle tube bevel gear worn Empty Throttle tube bevel gear worn on Thu Sep 14, 2017 3:24 am
uhoh7
uhoh7
1985 K100 RS made in 84. Never had the throttle upgrade. Throttle had huge play and you felt bump bump bump as you twisted. At first I thought this was some arcane beemer thing...LOL. Took it all apart and my splines on the tube (maybe chain gear too) are hammered. I feel them gnashing.
What are my options here? Can I still buy a tube and chain gear (haven't found one)?
Is there a boxer which uses the same tube?
Is there some aftermarket throttle assembly which will play nice with the stock from brake lever?
Thank you sirs Smile
2Back to top Go down   Throttle tube bevel gear worn Empty Re: Throttle tube bevel gear worn on Thu Sep 14, 2017 4:48 am
uhoh7
uhoh7
here is what they look like.....
Throttle tube bevel gear worn 36404506893_6ed2258f98_c
Stuff by unoh7, on Flickr
It's the 8mm, but i would kill for the correct part numbers. Now I see there are a bunch of different ones.....
I'm not interested in doing the new (post recall) throttle cable at the moment, I just want the right cams and tube for this one Smile
3Back to top Go down   Throttle tube bevel gear worn Empty Throttle Tube bevel gear worn on Thu Sep 14, 2017 5:48 am
Tom FKR
Tom FKR
G'day  I am pretty sure the throttle tube and bevel gear on my 93 K75 and my 92 R100R are the same. Not sure about your particular model. Maybe a search on Real OME website will clear this issue with part no. id. Cheers Tom
1993 K75 Slightly Modified
2010 BMW F650GS Twin
4Back to top Go down   Throttle tube bevel gear worn Empty Re: Throttle tube bevel gear worn on Thu Sep 14, 2017 6:26 am
have you actually tried lubricating the teeth ...
and the handle core to handle bars
and perhaps the cable is particularly tight , the throttle cable is supposed to have a Teflon core around the cable inner , I recently lubricated mine with a Teflon product and a cable injector device ...made a huge difference
and last have you lubricated the throttle bodies axels through the tbs ...
makes a world of difference
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OThrottle tube bevel gear worn Au-log10
5Back to top Go down   Throttle tube bevel gear worn Empty Re: Throttle tube bevel gear worn on Thu Sep 14, 2017 6:57 am
uhoh7
uhoh7
thanks you guys Smile
Charlie, tomorrow, I am going to file the rough edges on the teeth, clean all and see what happens. The cable pulls fine, but I am going to look at the throttle bodies as you suggest. What lube on the cam you think?
While I have you, do either of you recognize these wires?
Throttle tube bevel gear worn 36381943534_9f3dbdc6f9_c
They are right under tank, unconnected.....
the throttle gears are pretty wild, you don't think anyone ever rode this thing hard, do you?
Seems to run and drive well though. I never met the last owner. I love the bike, very fun to ride.
Oh jeez you gotta see this:
Throttle tube bevel gear worn 36383419874_1124c1fc25_c
Glasses by unoh7, on Flickr
There they were LOL What I don't get is that space. Why is not a storage area? You know what I mean, under the vents. Seems like a great place for two glove boxes. rendeer
6Back to top Go down   Throttle tube bevel gear worn Empty Re: Throttle tube bevel gear worn on Thu Sep 14, 2017 7:26 am
Gears on the throttle was a poor idea, IMHO. What it did do was allow BMW to route the cables very neatly along the handlebars. I've also found that even if you do keep the gears greased and the cables correctly routed, those gears still wear out in less than 20,000 miles. BTDT - wasn't amused. If you check closely, I'll bet you find that the teeth that are worst worn are those that engage at the speeds that are most often used.
And yes, there are two different versions of the throttle. I have no idea when they changed but someone here will know.
Connectors: the three-pin male connector is for the optional hazard switch. The two-pin male connector is for the optional heated grips. The three-pin female connector is (most likely) the 'connector for additional instruments'. Check the wire colours: if they are slate/blue, green/black and brown then that's it.
7Back to top Go down   Throttle tube bevel gear worn Empty Re: Throttle tube bevel gear worn on Thu Sep 14, 2017 8:08 am
Chocolate
Chocolate
 Hello!
The throttle has changed in 8/91.
I have a bike with the old throttle and a bike with the new throttle.
The old version has some play if turn the throttle and the new version reacts directly, nice and handsome.
8Back to top Go down   Throttle tube bevel gear worn Empty Re: Throttle tube bevel gear worn on Thu Sep 14, 2017 9:26 am
I can supply you with a throttle tube and chain gear.  Drop me a PM if interested.
9Back to top Go down   Throttle tube bevel gear worn Empty Re: Throttle tube bevel gear worn on Thu Sep 14, 2017 5:35 pm
uhoh7
uhoh7
Duck is looking for me, TY so much Smile
since this might help others to find the real part numbers or ID loose parts:
I believe this must be the original K100 setup:
Throttle tube bevel gear worn 37229403825_4bbb11a117_c
Throttle Cam Chain by unoh7, on Flickr
Throttle tube bevel gear worn 36831340870_8183252ecb_c
number might be definitive: 287.1-z7
Throttle tube bevel gear worn 37039349286_f15c0877bf_c
Nums by unoh7, on Flickr
might want to count the teeth on the throttle tube:
Throttle tube bevel gear worn 37229403685_740e5b835b_c
