1Back to top Go down    fuel gauge backlight on Sat Sep 16, 2017 3:43 am
club_c
club_c
Gents (and ladies),
1988 K100RS, my backlight in the fuel gauge is not working. Pulled the gauge to take a look but cannot simply remove the bulb. I didn't want to force anything, so thought I'd see if anyone has been here before me and knows the obvious little trick to remove the bulb.
1988 K100RS SE VIN 01477554
2Back to top Go down    Re: fuel gauge backlight on Sat Sep 16, 2017 4:37 am
@club_c wrote:Pulled the gauge to take a look but cannot simply remove the bulb. I didn't want to force anything, so thought I'd see if anyone has been here before me and knows the obvious little trick to remove the bulb.
I haven't been there before you. My bike only evolved to idiot lights. Maybe these images from the MAX BMW parts fiche will aid in visualization.
1995 K75T 68,000 miles
3Back to top Go down    Re: fuel gauge backlight on Sat Sep 16, 2017 4:40 am
1) Do it with the gauge face facing up. Otherwise the bulb can fall out and then you have to shake it like a six year old's toy to get it to fall out.
2) Twist the socket while pulling. You won't break anything.
3) Once the socket is out just push a little and twist the bulb counterclockwise.
4Back to top Go down    Re: fuel gauge backlight on Sat Sep 16, 2017 4:42 am
club_c
club_c
Yes that is all correct. I've had the back plastic case off, and can see the bulb socket (last picture) in the back of the gauge metal casing, however when I pull on it (gently so far), it doesn't move. If someone can confirm its just a press in fit I'll get more physical...
5Back to top Go down    Re: fuel gauge backlight on Sat Sep 16, 2017 4:43 am
club_c
club_c
@duck wrote:1) Do it with the gauge face facing up. Otherwise the bulb can fall out and then you have to shake it like a six year old's toy to get it to fall out.
Thanks duck. You and I were posting at the same time...
6Back to top Go down    Re: fuel gauge backlight on Sat Sep 16, 2017 6:26 am
yep just a press fit clubbie
good luck
7Back to top Go down    Re: fuel gauge backlight on Wed Oct 04, 2017 3:43 pm
club_c
club_c
"press fit". Maybe when it was installed in 1988. Today it was a pull and twist and grit the teeth kind of extraction. After all that the bulb was fine. Classic issue on these bikes: the ground on the back of the fuel gauge was corroded. Cleaned it up and now I can see my gauge at night. Thanks for the tip Charlie. I don't think I would have applied that much effort to pulling it out if I didn't know for sure it was a "press fit".
8Back to top Go down    Re: fuel gauge backlight on Wed Oct 04, 2017 6:00 pm
woohoo ! another win for you
