1Back to top Go down    HELLO FROM MICHIGAN on Fri Sep 15, 2017 3:29 pm
jpb6061
jpb6061
Another new member from Michigan... I have had an '88 K100RS for a few years now. finally feeling well enough after bypass surgery a couple years ago to start hitting the road again! Looked at the forum in search of tire information..... they seem to dry rot when sitting around!
2Back to top Go down    Re: HELLO FROM MICHIGAN on Fri Sep 15, 2017 10:14 pm
Bucky
Bucky
Good to hear you're better!! I'm in Upstate NY so I know what you're weather can be like (I think yours is worse) so get out there as soon as you can before the bad weather hits. And yes if they sit for an extended period of time dry rot sets in. Don't put off getting it replaced.
Happy riding,
Bucky
Anything worth doing is worth overdoing! (B-52 Crewdog Phil Smith)
1985 K100RT
3Back to top Go down    Howdy do from British Columbia on Sat Sep 16, 2017 12:20 am
Ace Handler
Ace Handler
@jpb6061 wrote:Another new member from Michigan... I have had an '88 K100RS for a few years now. finally feeling well enough after bypass surgery a couple years ago to start hitting the road again! Looked at the forum in search of tire information..... they seem to dry rot when sitting around!
Hello and welcome to the forums! I lived in Michigan once upon a time, Birmingham Farms, corner of Telegraph Road and Maple. Lived through the nearby craziness in the summers of '65 and '67 - wild, wild times!
Tires - I recently bought my first K and it came with Pirelli 'Angels' - and they are sweet! Just sayin'...
Wishing you many happy and satisfying years of safe riding! ;BMW;
Ace
"The World is a Highway, and we are but merely Riders"
1992 K100RS Perlsilber 16v. VIN 6493830
4Back to top Go down    Re: HELLO FROM MICHIGAN on Sat Sep 16, 2017 5:56 am
Welcome along.
Loads of information/advice/conflict about tyres on the forum...enter the word into the search box and be prepared to be overwhelmed.
K bikes as a whole don't like sitting - the rubber bits, including tyres, probably suffer most (including the rubber bits inside the fuel tank).
Good luck with getting yourself and your RS back onto the road...should be just enough time during Fall to get some good rides in before the ice and snow come along and force you back into your shed/garage to fix all those bits that you feel need fixing in time for Spring
Paul
"Gretel" K100LT 1989 (Silver Grey) (VIN 0177324 Engine No. 104EA 2789 2211) - 4th+ owner. September 2015 (58,500miles and counting....). Cat C Insurancewrite-off rebuild Feb 17
"Donor" K100LT 1990 (Red) (VIN 0178091 Engine No. 4489 2024) - 6th & final owner (crash write-off now donor bike). June 2012 (73,000 miles) to November 2013 (89,500 miles)
5Back to top Go down    Re: HELLO FROM MICHIGAN on Wed Sep 20, 2017 4:37 pm
SteveK1
SteveK1
Welcome. I'm in southeast Michigan. Where are you located? Is it a two-valve RS or a 4-valve?
BMW K1 1990
BMW R60 /5 1973
BMW R100R 1992
Honda CB360T 1975
