1Back to top Go down   Burning the afternoon oil Empty Burning the afternoon oil Sun Sep 03, 2017 7:39 pm
FreyZI
FreyZI
Recently finished putting Alda back together and fired her up for the first time in my ownership.  Hadn't been run for probably at least two years.  I did not mess around with engine, but everything else.  Supposedly it ran well before being dumped and then sitting for a year or more before I bought it last year.
She will start up, in fact reasonably easily.  However, she's burning oil.  I spotted some oil leaking out where the headers meet the gatherer to the muffler/silencer.  I haven't isolated which one (or more) yet.
So, what would you start with?
FYI, I have not overfilled oil, bike's only been on center stand.
2Back to top Go down   Burning the afternoon oil Empty Re: Burning the afternoon oil Mon Sep 04, 2017 12:51 am
How many miles?  Have you pulled the spark plugs to look at them?  What do they look like?  How much smoke?
3Back to top Go down   Burning the afternoon oil Empty Re: Burning the afternoon oil Mon Sep 04, 2017 1:21 am
Piston rings can stick from lack of use. Either run some high detergent oil through the bike for a hundred miles or so then change back to your preferred brand. Or just run it, they will sometimes free up with use. A  mates brick was a heavy smoker but it eventually settled down.
4Back to top Go down   Burning the afternoon oil Empty Re: Burning the afternoon oil Mon Sep 04, 2017 3:21 pm
FreyZI
FreyZI
Bike has, I believe, a little over 100K miles.
I checked spark plugs and it looks like PO changed them in his effort to get the bike running.  Of course, that wouldn't have done much good without an operable fuel pump.  Plugs hadn't been gapped correctly, as they were all considerably over .6mm.  I shortened the gaps to about .53 - .55 and stuck them back in.  I didn't notice any appreciable difference.
I do hear the timing chain underneath the valve cover.  Not sure how audible that is usually.
I posted a video to youtube ( https://youtu.be/e_kXFCKR2r0 ).  Smoke is worse as it warms up.
Cheers,
Frey
5Back to top Go down   Burning the afternoon oil Empty Re: Burning the afternoon oil Thu Sep 21, 2017 7:40 am
FreyZI wrote: Plugs hadn't been gapped correctly, as they were all considerably over .6mm.  I shortened the gaps to about .53 - .55
The specs allow a gap from 0.6 mm to 0.9 mm. Less than 0.6 mm isn't specified.
6Back to top Go down   Burning the afternoon oil Empty Re: Burning the afternoon oil Fri Sep 22, 2017 8:58 am
FreyZI
FreyZI
Yeah, the other day when I was looking for the piston ring gap specs I noticed that in the Haynes manual the spark plug gaps specs are wider.  I can't remember which resource I used that said 0.5 to 0.6.  If I find it, I'll note it here.  Incidentally, the head is off and the pistons are out, so I'll widen the plug gaps while everything is open.
7Back to top Go down   Burning the afternoon oil Empty Re: Burning the afternoon oil Fri Sep 22, 2017 10:08 am
FreyZI wrote: Incidentally, the head is off and the pistons are out, so I'll widen the plug gaps while everything is open.
I suggest you replace the current plugs with new plugs that are gapped correctly.
8Back to top Go down   Burning the afternoon oil Empty Re: Burning the afternoon oil Sat Sep 23, 2017 1:10 pm
FreyZI
FreyZI
PO put the plugs in as low hanging fruit.  They've only seen a few minutes of action.
