Overture
Overture
Overture's 84' K100RT Build - The Flying Rick Zq4jJmU
Hi All, Welcome to my resurrection of a 1984 K100RT!
First off some brief history of the Bike! As far as I know prior to me purchasing it it was owned by my work mate! And his brother in-law before that!
This is the early 2000's when she was still in one piece;
Overture's 84' K100RT Build - The Flying Rick SaxGRBd
Then after he (the brother in-law) dropped it 4 times;
Overture's 84' K100RT Build - The Flying Rick BFpUf2Z Overture's 84' K100RT Build - The Flying Rick Fniy4bT
Both panniers were broken the entire mount for the front fairing was held together with duck tap!
Then my work mate, did a at home naked conversion!
Overture's 84' K100RT Build - The Flying Rick CIbSghG
Which is where we stand now, a homemade bracket (complete with tech screws!~) holds the OEM headlight pretty well!
TBC!
1984 K100RT (Now Naked)
well we/ve seen worse
good luck
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OOverture's 84' K100RT Build - The Flying Rick Au-log10
@charlie99 wrote:well we/ve seen worse
I've done worse and it only took one off, not four!! Overture's 84' K100RT Build - The Flying Rick 44271
Overture
Overture
New fuel pump is in!.. I seem to only have a picture of the seized one.
Overture's 84' K100RT Build - The Flying Rick ICfkZrq
And first start; Anyone got a riders manual? I have no idea what that Yellow warning light is? (Did a quick search can only find info on the red lights etc.)
Anyone had any use of this product?
http://www.supercheapauto.com.au/Product/Septone-Ali-Brite-Aluminium-Cleaner-1-Litre/1747
Looks similar to Deoxit?
Also seem to have a slight fuel leak... new line is on the way!
Overture's 84' K100RT Build - The Flying Rick Sy2DZLk
yellow light is the  ...ahem ...choke lever activated ....there is a switch on the throttle cam activation to the throttle bodies ..(same type switch as brakes and clutch lever )
good work !!!!!
sounds like a k bike to me already
Overture
Overture
@charlie99 wrote:yellow light is the  ...ahem ...choke lever activated ....there is a switch on the throttle cam activation to the throttle bodies ..(same type switch as brakes and clutch lever )
good work !!!!!
Shes a little rough, but that was no choke... at least I'm pretty sure. Maybe a dodgey sensor? Or does the cable need to be adjusted?
Now I've looked up what sticker should be on the choke switch I know... Rolling Eyes ....
Forgive me lack of know how! I'm waiting for the service manuals to show up.
I've also let her run for about 30 or so minutes 2-3 times and shes not blowing smoke anymore and sounds way better.
Going to drop the oil and do the gearbox/rear drive area tomorrow.
Also looking at coolant options, the BMW stuff is crazy pricey?
Anyone used good old Green Penrite?
http://www.penriteoil.com.au/products/categories/motorcycle-go-kart/coolants/7-year-450000km-green-premix
A common fault from what I've been reading is the water pump, so she needs to be checked out!
Thanks!
maybe the switch is toast or just needs cleaning ?
wont be the first that we have seen go west
but possibly there is a slight adjustment issue  with the cable - or throttle bar set screw
I guess in time that will be sorted ...after a bit of a tune up
the service manuals are available right here in the forum
just look for the downloads section ....prerequisites are number of posts ...and the magic password
good luck
Overture
Overture
@charlie99 wrote:maybe the switch is toast or just needs cleaning ?
good luck
Might need a good cleaning, I'll dig in tomorrow when I do the fuel line and take the tank off for the first time.
Overture
Overture
Oh wow, thanks Duck! I'll read into that tomorrow.
Legend.
Good progress. I can't believe the state of the fuel pump rubber. I've seen pictures of them before but it never ceases to amaze me.
Overture's 84' K100RT Build - The Flying Rick Ir-log11 88....May contain nuts!Overture's 84' K100RT Build - The Flying Rick Ir-log11
Try soaking the old pump in vinegar for a week or two. Sometimes soaking and applying 12v briefly then alternating the + & -  can break them free. If it has signs of life and it looks like it is trying to move either resoak or you can up the voltage very briefly to 18v and try alternating the connections. Always good to have a spare.
Overture
Overture
@MartinW wrote:Try soaking the old pump in vinegar for a week or two. Sometimes soaking and applying 12v briefly then alternating the + & -  can break them free. If it has signs of life and it looks like it is trying to move either resoak or you can up the voltage very briefly to 18v and try alternating the connections. Always good to have a spare.
It's soaking now Martin thanks!
Some more quick updates, ran the bike until the fan came on 15~ minutes, noticed a milky residue at the sight glass.... and behold I've got a chocolate milkshake in my engine.......
Sooo looks like I'm rebuilding the pumps/seal wise! or I may follow Chris Harris' advice and get a used/reconditioned unit.
Otherwise I'm waiting for parts now, but I'll update the pics soon!
-C
Overture
Overture
Lost of progress, kinda dropped off the radar.
I've had injector problems for a couple of weeks, finally ordered some Standard FJ27 Injector's from RockAuto as mine are still not spraying.
Rewired the Acewell Dash and a new LED headlight from Max Design. Also put on a new lower plate mount in preparation for the new seat and configuration.
Overture's 84' K100RT Build - The Flying Rick CwVNEsQ
Overture's 84' K100RT Build - The Flying Rick GZe0sYm
Overture's 84' K100RT Build - The Flying Rick Ssz3bpg
Also cleaned the garage! Still need to organise way more, it was getting pretty bad.
Overture's 84' K100RT Build - The Flying Rick Ntmk0hL
Overture
Overture
Back on the issue of the injectors, I've got fuel at the rail. The injectors connections are flashing with a test light.
Fuel pump is running perfectly and the pin test on the ECU plug said everything was fine, anyone got any other idea's?
I did have the plug to the ignition unit slightly unseated but it's now reconnected. Could I have killed a relay? But if it was the fuel relay wouldn't it also kill the pump?
It's super strange as the bike was running perfectly.
Unless all 4 injectors just died as the fuel rail was pretty clogged with crap and needed a soak in carby cleaner.
I should also mention when 12v is directly applied to the injectors they work 100%.
