1Back to top Go down   Running hot but not overheating Empty Running hot but not overheating on Tue Sep 19, 2017 10:59 am
Garyk100
Garyk100
In the last year my K has been running hot, the fan was switching on regularly and the bike would cool down, the next stop it would warm up and switch on again, seemed like it was running a temp just under where the fan kicks in, I fitted a new BMW (expensive) fan about 16 years ago, and used to let it idle in the driveway to make the fan run and not seize, as it rarely came on, so I pulled the radiator out thinking its full of bugs, no bugs or crap so cleaned it, pulled the thermostat out and found it was stuck open about 4 to 5mm, replaced it with a corolla one, I have ridden around for a week and all is back to normal yay. Hope this helps others that may experience similar probs, cheers Gary
Forgot to say that the engine gets up to operating temp a lot quicker than before, and that is a good thing as most rides are short around town.
Last edited by Garyk100 on Tue Sep 19, 2017 9:19 pm; edited 1 time in total (Reason for editing : Thought of more)
The early bird catches the worm, but the second mouse gets the cheese
1991 K100rs16v
1993 K1100LT
2Back to top Go down   Running hot but not overheating Empty Re: Running hot but not overheating on Tue Sep 19, 2017 6:39 pm
top news gary
always good to hear of a change has happened after a repair
thanks for sharing
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%ORunning hot but not overheating Au-log10
3Back to top Go down   Running hot but not overheating Empty Re: Running hot but not overheating on Tue Sep 19, 2017 7:12 pm
Good result, what model Corolla for future reference.
4Back to top Go down   Running hot but not overheating Empty Re: Running hot but not overheating on Tue Sep 19, 2017 9:13 pm
Garyk100
Garyk100
@MartinW wrote:Good result, what model Corolla for future reference.
Not sure of the model Toyota Corolla but I bought the high flow and new rubber ring,
Tridon High Flow Thermostat - TT2014-180, from supacheap
Last edited by Garyk100 on Tue Sep 19, 2017 9:15 pm; edited 1 time in total (Reason for editing : Spelling error)
1991 K100rs16v
1993 K1100LT
5Back to top Go down   Running hot but not overheating Empty Re: Running hot but not overheating on Tue Sep 19, 2017 9:37 pm
hi martin
most of the corolla s from 86 through 96 use the same
reference  ae 86 ...ae 92 , ae 101 ...etc
the new addition is the high flow version from tridon with about an extra 3- 5mm diameter flow port...not quite 2 x  price of the standard version
but depends on what your tying to achieve
6Back to top Go down   Running hot but not overheating Empty Re: Running hot but not overheating on Wed Sep 20, 2017 8:24 am
Thanks fella's I have seen various reviews on whether you can or cannot use Corolla thermostats. Some with modification to the thermostat and others saying the "O" rings need to be changed. So it's good to see local content on them.
7Back to top Go down   Running hot but not overheating Empty Re: Running hot but not overheating on Wed Sep 20, 2017 2:25 pm
Garyk100
Garyk100
I bought the high flow version as they had no stock of the standard, also the rubber ring that SCA offered was to big Tridon TTG11 @54mm $3.99 it did not fit tightly around the thermostat, so I went though all the packets till I found one that fitted snugly and of the same profile it fits perfectly Tridon TTG26 @48mm $13.69, big price difference, if I had time and looked around I probably could have found a cheaper o ring. Would be interested if anyone is using a standard flow.
1991 K100rs16v
1993 K1100LT
8Back to top Go down   Running hot but not overheating Empty Re: Running hot but not overheating on Wed Sep 20, 2017 5:06 pm
a few are gary
yes the ttg 26 is the one to get ....fits just nicely in the hole and takes up well with the front cover holding it all in firmly
