1Back to top Go down   Side stand for 1985 K100rs Empty Side stand for 1985 K100rs on Tue Sep 19, 2017 3:51 am
cliverocky
cliverocky
My side stand has rusted off anyone have one for sale
2Back to top Go down   Side stand for 1985 K100rs Empty Re: Side stand for 1985 K100rs on Tue Sep 19, 2017 7:29 am
Chocolate
Chocolate
Hello!
Try to find a K1100 K100 16V CENTER STAND, they last for ever.
I just changed my to a K1100 K1100 CENTER STAND.
There is on on EBay Australia rusty for sale.
You can use the old side stand
Fits perfectly
Old k100 75 4V Stand
Rounded legs that break
Side stand for 1985 K100rs Ständer-Hauptständer-Seitenständer-BMW-K75-K100-2V-K
The good main Stand from a K1100 100 16V
Massiv straight legs
Side stand for 1985 K100rs 17187d471876d4831ed2476545e83dc6a
3Back to top Go down   Side stand for 1985 K100rs Empty Re: Side stand for 1985 K100rs on Tue Sep 19, 2017 2:43 pm
The 4V center stand is slightly shorter then the 2V center stand.  Sometimes this is an issue. If it is then you can just add an M10 washer or two to the bolts between the center stand bracket and the transmission.
4Back to top Go down   Side stand for 1985 K100rs Empty Re: Side stand for 1985 K100rs on Tue Sep 19, 2017 4:04 pm
@duck wrote:The 4V center stand is slightly shorter then the 2V center stand.  Sometimes this is an issue. If it is then you can just add an M10 washer or two to the bolts between the center stand bracket and the transmission.
 + 1. I found getting my LT up on the old stand a bit of an effort. The later stand is much easier. Remeber you need the whole assembly so if you are already into a side stand then get a complete 16v or K1100 centre stand and put a new bush and bolt in it for the side stand pivot while you're at it.
Side stand for 1985 K100rs Ir-log11 88....May contain nuts!Side stand for 1985 K100rs Ir-log11
5Back to top Go down   Side stand for 1985 K100rs Empty Re: Side stand for 1985 K100rs on Wed Sep 20, 2017 1:40 am
Is it just the side stand or do you want a complete assembly, centre stand and all?
6Back to top Go down   Side stand for 1985 K100rs Empty Re: Side stand for 1985 K100rs on Wed Sep 20, 2017 8:50 am
cliverocky
cliverocky
@RicK G wrote:Is it just the side stand or do you want a complete assembly, centre stand and all?
Only need side stand as it was just the extension that broke
7Back to top Go down   Side stand for 1985 K100rs Empty Re: Side stand for 1985 K100rs on Wed Sep 20, 2017 9:22 am
Chocolate
Chocolate
Found this on eBay Australia:
Side Stand
Main Stand
Main Stand from a K1100 !  Cheaper an better
8Back to top Go down   Side stand for 1985 K100rs Empty Re: Side stand for 1985 K100rs on Wed Sep 20, 2017 1:49 pm
That's the little tab, part of the main plate that bolts to the gearbox?
9Back to top Go down   Side stand for 1985 K100rs Empty Re: Side stand for 1985 K100rs on Wed Dec 20, 2017 10:53 am
have a good solid complete assembly for a 84-85 model....if you still need it PM me.
KKlompy Side stand for 1985 K100rs 2854237993
Side stand for 1985 K100rs Au-log10
