1Back to top Go down   Fuel pump suspension rubber  Empty Fuel pump suspension rubber on Mon Sep 25, 2017 6:32 am
Garyk100
Garyk100
Hi all, I am chasing a small fuel suspension rubber 43mm, a good used one would be good, the k11 I acquired now has my twice repaired large pump from my RS it's lasted 15yrs, so I have a commodore pump on its way but like all the rubber bits out of the K11 the small suspension rubber is more like soft licorice, let me know if any of the Krew have one. Cheers Gary
The early bird catches the worm, but the second mouse gets the cheese
1991 K100rs16v
1993 K1100LT
2Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Mon Sep 25, 2017 7:50 am
3Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Mon Sep 25, 2017 9:16 am
Garyk100
Garyk100
Thanks Rick, motobins is the best price less than half the price of Aussie one, they are a bit short of details only a pic, would it be the zz16694
https://www.motobins.co.uk/mobile/bmw-parts3.php?bikeref=K100&P=3&model=K%20Series&M1=79&M2=14630
1991 K100rs16v
1993 K1100LT
4Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Mon Sep 25, 2017 9:26 am
looks about  right ...for k 16 valve models and k1100
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OFuel pump suspension rubber  Au-log10
5Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Mon Sep 25, 2017 9:30 am
Garyk100
Garyk100
That's what I thought, thanks will pm you, re drop off of the dash Charlie
1991 K100rs16v
1993 K1100LT
6Back to top Go down   Fuel pump suspension rubber  Empty Fuel pump on Tue Sep 26, 2017 7:12 am
Garyk100
Garyk100
Ordered the motobins one, got the commy pump today but no + or - marks on the pump no instructions but does come with a rubber that fits under the pump,I have messaged the seller waiting for a reply, so 2 questions if anyone can answer, which is positive and negative and is the rubber to help hold the filter on or to fit onto the commodore bracket, or do I put the pump in a jar of petrol and make sure it pumps out,
1991 K100rs16v
1993 K1100LT
7Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Tue Sep 26, 2017 4:25 pm
there is a difference on the terminals for + and - ...and will only fit one way
from memory 3 and 4 mm terminals on the pump
put it in a jar with fuel and pulse the power to it  to confirm the polarity  and function
careful with the fuel coming out ....tube to another jar ?
question though  isn't the commodore pump 52mm ?
I had a look at my falcon ed pump  (first time actually ) its 42 mm and spade terminals   4.8mm and 6.3mm +
good luck
8Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Tue Sep 26, 2017 7:24 pm
Garyk100
Garyk100
Both terminals are the same size and is a small pump only about 36mm, jar of petrol sounds the go, cheers
1991 K100rs16v
1993 K1100LT
9Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Tue Sep 26, 2017 9:31 pm
The VL dunnydore pump is 52mm but later models have smaller diameter or it may be for a VL and have a rubber sleeve to get it to 52mm
10Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Wed Sep 27, 2017 7:50 am
Garyk100
Garyk100
Thanks Rick, sorted out the elect connection, just waiting on motobins for the suspension rubber, it gives me time to try and get the new k running on all 4 cyl, it's not the coil, must be the injectors, cheers
1991 K100rs16v
1993 K1100LT
11Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Wed Sep 27, 2017 3:26 pm
If you get stuck testing and cleaning the injectors, give me a yell.
12Back to top Go down   Fuel pump suspension rubber  Empty Injectors on Wed Sep 27, 2017 8:03 pm
Garyk100
Garyk100
Thanks Martin, when I start the bike for a few seconds then touch the header pipes 2 and 3 are hot but 1 and 4 are stone cold, swapped the coil but made no difference, after reading lots of posts about bikes sitting, I think this one has sat for a long long time, and the injectors are blocked, will take them out and check as soon as I get time, cheers Gary
1991 K100rs16v
1993 K1100LT
13Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Thu Sep 28, 2017 3:55 am
Gary if you have a compressor I could drop off my test rig. I normally go for a Saturday blast and I also have a laser temp gauge an ultrasonic cleaner and just about anything else tool wise.
14Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Thu Sep 28, 2017 4:23 am
you have checked the ignition leads gary ?
and the primary wiring to the coils from the motronic unit ?
a meter across the coils should show some activity at start
15Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Thu Sep 28, 2017 5:18 am
Do you have spark on all the leads.
16Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Thu Sep 28, 2017 8:02 am
Garyk100
Garyk100
Hey guys thank you so much for help, lost for words. Will be working on the LT after the weekend as I am away for few days, Martin the offer will be great, I am learning about fuel injectors from the forum, so the tools you speak of will make sense as soon as I learn more, yes I have spark to all four cyl, did it ass about face, fitted the coil from my k10016v first and it still only ran on cyl 2-3, then I pulled the leads off one at a time and used a spare plug and had good spark to all, my next step was to remove the injectors and swap 2and3 for 1and4 and see if I get heat at the header from the change, and if 1 and 4 heat up it means I have 2 blocked injectors, again thank you for the help, Gary
1991 K100rs16v
1993 K1100LT
17Back to top Go down   Fuel pump suspension rubber  Empty Re: Fuel pump suspension rubber on Thu Sep 28, 2017 9:24 pm
Gary I am generally available Saturdays, Mondays and Tuesdays just email me when and if required.
