1Back to top Go down   Exhaust studs Empty Exhaust studs on Tue Oct 10, 2017 11:42 am
gabriel
Hi everyone
I recently replaced the exhaust studs on my 1984 k100.
I decided to use an alternative to the genuine parts.
The genuine exhaust studs have an expansion joint.
The studs motobins and Motorworks sell don't have this.
Due to financial constraints, I decided to use m8 bolts and cut them to size.
I purchased m8 high tensile? Yellow zinc bolts from Bunnings.
Retail price was $8.00.
I am concerned because the bolts I use do not include the expansion joint ( section of the stud which is not threaded)
I presume this is to allow for expansion of the exhaust headers.
Should I be concerned?
I have tightened the exhaustnuts firmly and I doubt have made Any allowances for the expansion of the motorcycle components due to heat from the exhaust components.
I intend to replace the studs with the genuine parts as soon as my financial situation improves.
Any suggestions?
all advice is appreciated.
Thank you for your time.
Regards
Gabriel
2Back to top Go down   Exhaust studs Empty Re: Exhaust studs on Tue Oct 10, 2017 12:29 pm
I certainly wouldn't be concerned about doing it that way, just use some never seize on the threads especially in the head.
3Back to top Go down   Exhaust studs Empty Re: Exhaust studs on Tue Oct 10, 2017 2:30 pm
As Rick says, it should not be a problem. I wouldn't worry too much about replacing them later either.
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
4Back to top Go down   Exhaust studs Empty Re: Exhaust studs on Tue Oct 10, 2017 2:43 pm
+ 2  Exhaust studs 112350
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OExhaust studs Au-log10
5Back to top Go down   Exhaust studs Empty Re: Exhaust studs on Tue Oct 10, 2017 5:19 pm
gabriel
Thanks.
