1Back to top Go down   Recommended oils?? Empty Recommended oils?? Mon Mar 14, 2016 7:06 am
Reg
Reg
Any body know recommended oils for engine/ gear box/ final drive for the K11??
2Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 9:03 am
Jesus Reg....don't start the  oil discussion again.  Rolling Eyes
I'm using Total 15w 40 in the engine because it's what I had to hand. Bricks aren't known for Oil related failure SF or SH spec
Hypoid Gear oil API class GL-5  SAE 80w/90 for the Gear box and FD.
Recommended oils?? Ir-log1188....May contain nuts!Recommended oils?? Ir-log11
K75RTP - 1994
3Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 9:29 am
With a bit of molyslip in the gearbox and FD Very Happy . IIRC there was something not quite right with the SG grade oil spec for the Brick.
4Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 9:32 am
Aww no!! Not another oil thread.... Someone had to say it 🤡
Engine Oil: Nulon Full Synthetic 10W40
GB/FD Oil:  Nulon Synthetic 75W90
BMW do recommend synthetic engine oil and I think issues like sprag clutch problems are caused by using a mineral oil with low detergent.
 Recommended oils?? Austra12    Fuel:  95 Octane
5Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 9:34 am
Kyle10
Kyle10
Close this discussion as soon as possible,  please. It never ends well.
Just buy something reputable and slippery and change it regularly; your bike will love it.
1985 K100rt 0052183
1983 Honda VF750 007713
6Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 10:05 am
Reg wrote:Any body know recommended oils for engine/ gear box/ final drive for the K11??
Ah now is this like the debate between Guinness and Murphys?
How are you for advice on tyres?
7Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 10:11 am
I have used Shell HX5 in everything I owned for more years than I can remember, it's always been good but there are many other oils out there that are just as good and far better than what was available 20 to 30 years ago when these contraptions were made.
You can use synthetic and increase the intervals between changes. I have just serviced the K1100 and have put synthetic Nulon in the transmission and drive. It very definately changes smoother especially on the down change.
8Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 10:16 am
Must...  Not...  Post..........
No...   No...  Must not...  Post...
..........Shell......     ....Rotella T6...
.....Full Synthetic...             ......   $21.36/gallon...    Walmart
.......Walmart...       ...GL-5....    ...Synthetic 75W150........      ......I add... ...
...2 tsp.........       .....Molybdenum disulfide........        ....powder.......
........To....      ....trans.......       ...for........    Silky smooth......
.....shifting...........
..A....
      ....R.R....R
                  ...R.......R..
                               .....RG..H
9Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 11:37 am
Ah yes those little US gallons. We get bigger gallons over this neck of the woods.
I guess something to do with the 'aye me hearties' lads landing the rum US side with less than the loaded amount and saying 'it evaporated through the oak barrels' while singing 'What will we do with the Drunken Sailor'.
They didn't worry about oils or tyres........
When we were in France last year Bob put some baking powder .....Molybdenum disulfide........        ....powder in the bikes too. Its good stuff.
10Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 11:58 am
Just don't put molybdenum disulfide in the engine.  It will kill your sprag clutch.  DAMHIK
You have been warned.  Your oil can be too slippery.
11Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 12:20 pm
Point-Seven-five wrote:Just don't put molybdenum disulfide in the engine.  It will kill your sprag clutch.  DAMHIK
No, it went in gearbox and final drive....
12Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 3:34 pm
Corkboy
Corkboy
Recommend oil in the engine, gearbox, and FD,
In a word......Yes   Laughing
I would heartily recommend oil in these locations.
Now, would I recommend tyres on the wheels, that's another matter.
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
13Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 5:16 pm
Motorbike Mike
Motorbike Mike
Kaptain Holister wrote:Aww no!! Not another oil thread.... Someone had to say it 🤡
I use these synthetic grades in all my 8 and 16 valve K's without any issues. My K100 track bike has been mercilessly thrashed on track days often up to the rev limiter and all's well. Gearbox and final drive also good.
What else could you want from your oil??
14Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 7:22 pm
I saw that, and wanted to warn anybody who might think that putting it in the engine is a good idea.
I made the mistake of using Honda Moly 60 as an assembly lube when I did my cylinder head.  After an hour or so of run time the sprag stopped working.  I had to do a backspin to get the engine started with a full can of Seafoam, let it run for a half hour and did an oil change to get the moly out.
15Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 7:35 pm
"Close this discussion as soon as possible,  please. It never ends well.
Just buy something reputable and slippery and change it regularly; your bike will love it."
^ This.
I will add...use oils to suit the climate where you live and the temperature you will encounter before your next oil change.
16Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Mon Mar 14, 2016 9:42 pm
The Nulon Full Synthetic engine oil I use comes with moly already in it (Molybdenum Dithiocarbamate).
17Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 4:29 am
blaKey wrote:"Close this discussion as soon as possible,  please. It never ends well.
^ This.
agree Blakey
18Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 4:39 am
Chocolate
Chocolate
I would recommend 20W50 this is better for hot temperatures, I don't think anybody will use the bike -20Celsius
this is the 30Years old BMW recommend oil, the modern equivalent would be SAE 75W-140 API GL-5
Just my 5 cent
19Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 6:38 am
Reg
Reg
Well everyday is a school day, thats religion, Politics and oils, not to be discussed..
well i ended up getting.....
A bottle of engine slippy stuff,
2 bottles of gear stuff,
1 new box full of sparks,
and some coloured stuff to keep it cool..
and stopped of for a pint of blackstuff on the way home..
But thanks for advice
20Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 9:38 am
Chocolate
Chocolate
Reg wrote:
and stopped of for a pint of blackstuff …
this is the correct stuff, I use the same :-) It runs perfect, but you have to fill up more often!
21Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 9:55 am
Need to watch that black stuff. It can burn the exhaust valve and tailpipe if you run it too rich.
22Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 10:02 am
Chocolate
Chocolate
Hey Olaf!
Could you please post a picture of you tailpipe, I don't think BMW is still selling this model :-)
23Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 10:09 am
You asked for this........Recommended oils?? K75_re11
24Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 10:10 am
This one is the obsolete carb eater carburettor model....
Recommended oils?? Bakedb10
25Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 11:02 am
Chocolate
Chocolate
Recommended oils?? Zigzagever-1111266538
26Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 11:28 am
Reg
Reg
We have the proper black stuff here in the west, I hear tell there is some other copycat muck down south, that stuff will defo give you down pipe problems....
go on the corkbuys .....Smile
27Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 12:26 pm
He looks well oiled anyways......
Look what this talk of oil started....!!
Just as well there was no mention of tyres.
28Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 2:23 pm
92KK 84WW Olaf wrote:He looks well oiled anyways......
Was so...Corkboy (post No.12) mentioned the T word. My simple mind was unable to contemplate the magnitude of an oil and tyre discussion in the same moment of consciousness so I failed safe and "disregarded the post" - until now.
There was some talk of having a mass log on recently - perhaps it should be expanded to getting the most people on line ever and try and crash the www and overload the forum with the most different opinions on the choice of oil at the same time?
Recommended oils?? Uk-log10 Recommended oils?? Sco-lo15
                              Paul  Recommended oils?? 905546712
29Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 2:54 pm
Last Saturday week I wandered over to the local Honda dealer, happily located beside the local BMW dealer......
Parked outside the showroom was a rather nice K75 with a sprint fairing....so I eyed it up to see it was shod with Bridgestones....BT45 front and rear. Just like mine!
Tyres are an emotional subject. Sometimes even over inflated. Does this need a new tread?
30Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 3:54 pm
SHOOT HIM!!!!!!!!
31Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 4:35 pm
Dai wrote:SHOOT HIM!!!!!!!!
A little harsh Dai...it's been a long day and he is obviously tyred and, whilst (lucky b'stard) he is not balding, he may still be losing his grip. Laughing
32Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Tue Mar 15, 2016 5:08 pm
Seems like I need to keep a low profile or be retyred with India rubber.
It's all Reg's doing...........
33Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Wed Mar 16, 2016 1:22 am
In my best written Irish accent.
Shocked I am aghast at the frivolity displayed on dis sacred Oil Tread. Have a torght for dose who worship the Golden Viscosity..... Recommended oils?? 8157
34Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Wed Mar 16, 2016 6:30 am
Kaptain Holister wrote:In my best written Irish accent.
Leprachaun+1
See, he holds the golden viscosity in high esteem.
35Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Wed Mar 16, 2016 6:43 am
 Jesus...Don't start the Larger debate again  Rolling Eyes
K75RTP - 1994
36Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Wed Mar 16, 2016 6:47 am
 Jesus...Don't start the oil tyres Larger debate again  Rolling Eyes
Green Kangaroo Fixed that for you Will!!
37Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Fri Mar 18, 2016 11:53 pm
I'd agree Choco, its maybe a little low in viscosity but the K is an over engineered machine with fine tolerances, polished contact surfaces, hardchromed crankshaft journals and nickasil bore linings etc. From what I've read it can handle a quality modified synthetic 10W40. Just my opinion. She's due for a change now and I'll be using same oil but in a 15W50
75W140 gear oil is a much higher viscosity oil not suitable for general road use. Its used in drive trains under excessive load like trucks. This viscosity in a BMW drive train would produce higher than normal running temperatures with greater drag and a marginally lower power output. Bearings would suffer due to reduced oil flow imo. 75W90 is the correct oil to use
Just my 5 cent
38Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Sat Mar 19, 2016 3:21 am
Chocolate
Chocolate
20W50, 10W50 or 10W50 is a question of temperature where we live. In the end they are all OK
I'm not sure with this, in the German forum they all recommend SAE 75W-140 API GL-5 as newer and better oil then the 30 years old BMW recommend 75W90.
Just my 5 cent
Hey Kaptain
But I fell you got a better knowledge about the oil then I have.
The German forum user use and swear on:
Motul 75W140
https://www.motul.com/system/product_descriptions/technical_data_sheets/108/Gear%20Competition%2075W140_GB.pdf
doesn't mean they are right :-)
I'm now a bit irritated, If I wouldn't have asked live would be easier.
39Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Sun Mar 20, 2016 8:54 pm
I think you are getting worried about the 75w, its the base oil used to flow around the gearbox, the index is the capacity to handle pressure, that is its capable of acting like 90weight in the heat of battle, so if the new stuff is indexed to be capable of handling the heat of battle all the way to 140, its nice but still going to flow like a 75 weight, just wont shrink form battle up till 140.
40Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Sun Mar 20, 2016 9:58 pm
In my dry clutch Beemers I use Castrol (or other when Castrol's not available) full synthetic 75W140 in the gearbox and final drive, have for years. It takes the heat from the catalyst, where equipped, doesn't leak out past seals and I've never had the dreaded final drive big bearing failure - knock on wood.
In the engines of those same bikes I use cheap and plentiful (about US$5 per quart) Mobil 1 full synthetic 15W50 year round. My very high mileage R1150RT doesn't burn a drop between oil changes when on roadtrips and about half a litre between changes in mainly stop 'n' go city or peak hour traffic during the heat of Summertime.
~Mac McCleary
41Back to top Go down   Recommended oils?? Empty MoS2 or something...fairy dust! Thu Oct 19, 2017 8:06 pm
Ace Handler
Ace Handler
Pardon my ignorance, please Question - I have never been formally introduced previously to the benefits of adding Molybdenum Disulphide to geared drives, but sounds like a miracle product!  Why isn't it a standard additive for final drive oils is the question (niche market!).
Canadian Tire has tubes of high pressure grease with 'some' MoS2 in it (how much doesn't say) and it was on sale.  But the thought of shooting grease into my gearbox/final drive didn't really seem like a good idea so I gave that a pass.  But I found this on eBay and it appears to be just straight Mo.  Will this work?  It's an awfully decent price I'm thinking...  Here's a pic of the item description, any and all inputs welcomed Smile
Recommended oils?? 100g_310
"The World is a Highway, and we are but merely Riders"
1992 K100RS Perlsilber 16v. VIN 6493830
42Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Thu Oct 19, 2017 9:27 pm
I'm not sure about using that straight molybdenum powder, especially since the particle size sounds too large.
The stuff I use is Molybdenum disulfide in a 1.5 micron particle size.
https://www.ebay.com/itm/Molybdenum-Disulfide-1-5-Micron-Powder-2-Ounces-99-Pure-SHIPS-FAST-/391442186584?hash=item5b23c5c158:g:ZhwAAOSwzgRWyBxe
43Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Fri Oct 20, 2017 9:24 am
Ace Handler wrote:Pardon my ignorance, please Question - I have never been formally introduced previously to the benefits of adding Molybdenum Disulphide to geared drives, but sounds like a miracle product!  Why isn't it a standard additive for final drive oils is the question (niche market!).
Because everything has already been discovered...
Molybdene may be un good lubricant, but it may also not match with the components of transmission, creating electrolytic reactions or modification of acidity that permit corrosion, often on pieces made of brass and bronze.
The micronised graphit used to be the fashion some years ago. Miracle product!
And it is indeed...in dry conditions. It's a miracle lubricant in locks, for example. Many garages used this powder in engines and transmission, with evident benefits at short term. Lubricant brands even sold oil with graphite (Antar molygraphite) .But at long terms, the graphit was pumping oil, making sort of pasta that stucks the oil conducts in engines, which failed.
An old mechanic impressed me with that sorcecer's magical powder. "Just add a small glass in your gearbox, you'll see, it will make it smooth and silent". And it dit.
But 2000 km later, it became worst than before, hard and noisy, all the seals were leaking. Hey, it's a super lubricant, so it even leads oil through the lips of the seals...(it depends a lot of the material of the seal)
When I opened my gear box to change the seals, not a single drop of oil could be drained. Removing the cover, I discovered that the powder had mixed with the oil and was plastered on the gearbox carter, but no oil was remaining at the bottom nor on the shafts.
Sorry, but there's no miracles in mechanics. Simply stick with the manual guide, you'll avoid problems.
44Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Fri Oct 20, 2017 10:51 am
BobT
BobT
I used the powder in the oil on my, Wills (88), and Olafs gearboxes. About a teaspoon in the gear oil. It used to be uses in engine oil on this side of the Atlantic, it was called Molycote or Liquid Moly oil, and a few other trade names. When you put it in the gearbox, you can feel the difference within 100 kms.
It is not acidic and will not affect any components inside the gearbox. It is a great lubricant for anything under pressure, such as gears.
We used it in the aviation industry for many different things.
It is no longer used in engine oils, because modern fully synthetic oils are so good that they need nothing else.
45Back to top Go down   Recommended oils?? Empty Vescosity? Fri Oct 27, 2017 4:06 pm
flyinglow
flyinglow
So why not a 10w-30 vs. 10w-40 or 20w-50?  Most cars are running 0w and 5w synthetic these days and are fully capable of 200,000 if maintained?   The K engines aren't running any hotter than the car engines?
46Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Fri Oct 27, 2017 4:48 pm
They're not running hotter, but the viscosity depends of the oil pump capacity and the lubrication system.
It's not designed for a fluid oil, you won't reach the minimal oil pressure using a 10w30 and your engine won't like it.
There's no advantage for using a low viscosity index -below 20w50- unless you're riding under -10°Celsius (15°F). Who does?
47Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Fri Oct 27, 2017 5:31 pm
BobT
BobT
jbt wrote:There's no advantage for using a low viscosity index -below 20w50- unless you're riding under -10°Celsius (15°F). Who does?
Oh yes there is an advantage. In cold weather a 5w50 will circulate the engine much quicker than a 20w50 will at start up. when warm they will both be a 50 so the same.
48Back to top Go down   Recommended oils?? Empty Re: Recommended oils?? Sun Oct 29, 2017 10:02 am
I use Nulon synthetic 10w50 which has a moly additive.
LiquiMoly and Molycote products are available in Oz as far as I know.
