1Back to top Go down    Fork top plug Empty Fork top plug on Sun Oct 22, 2017 1:14 am
Oliveri
Oliveri
Need 2  Fork top plugs for a '88 K100 RT. Mine are threaded and are leaking at the filler bolt.
Any help is truly appreciated.
"Keep the paint up, and the rubber down
 Fork top plug Bike
1988 K100RT...#0096960 ..."Heisenberg" ...Status: Work in progress
http://www.vintagesteelworks.com
2Back to top Go down    Fork top plug Empty Re: Fork top plug on Sun Oct 22, 2017 2:15 am
I drilled the holes out a bit and put schrader valves in, not rubber but the all metal, but no air pressure worked great.
3Back to top Go down    Fork top plug Empty Re: Fork top plug on Sun Oct 22, 2017 5:48 am
@Oliveri wrote: Mine are threaded and are leaking at the filler bolt.
Have you tried to change the aluminium gaskets?
4Back to top Go down    Fork top plug Empty Re: Fork top plug on Sun Oct 29, 2017 5:26 am
Oliveri
Oliveri
That's a good idea Rick, i like it. Inge, the thread of the top's is really bad the 10mm filler bolts are almost loose.
Thanks for the reply, i ended up finding a couple from an old BMW nut that lives about 40min away. All is well again.
 Fork top plug Bike
5Back to top Go down    Fork top plug Empty Re: Fork top plug on Sun Oct 29, 2017 8:30 am
Sounds like Bernie S
6Back to top Go down    Fork top plug Empty Re: Fork top plug on Mon Oct 30, 2017 3:16 am
or Ray Peak at wonglepong
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%O Fork top plug Au-log10
