Motorbike Mike
Motorbike Mike
I've just collected a 27141 miles K1200RS engine, gearbox, loom, ECU, throttle bodies and oil cooler that came my way because I asked if a guy breaking a KRS had anything left-it's always worth the question.
I don't know what I'm going to do with it yet but I'm sure I'll think of something. Very Happy
Cheap K1200RS engine, 'box etc had to be bought. Img_5311
wow!!...what a win
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OCheap K1200RS engine, 'box etc had to be bought. Au-log10
Motorbike Mike
Motorbike Mike
It is Charlie. I wanted to use the 6 speed gearbox but in all honesty I can't be bothered with the fabrication involved-I have too many projects on the go already. lol!
With a five speed 'bellhousing' and bits of K11 & K12 clutch it'll bolt right in to any K100/K1100 frame. It's an instant 130hp +/- from the usual 90/100hp...and the torque increase alone makes it worth it.
1987 K100RS, '89 K100 w/K1100RS engine, '93 Framed K11/K12 engine 'Big Block', '96 K1100RS, '09 K1300GT, '07 K1200R, '95 R100 Mystic & '77 R75/7.
Motorbike Mike
Motorbike Mike
@Two Wheels Better wrote:With a five speed 'bellhousing' and bits of K11 & K12 clutch it'll bolt right in to any K100/K1100 frame. It's an instant 130hp +/- from the usual 90/100hp...and the torque increase alone makes it worth it.
I do have a spare motor that I could steal a bell housing from so it will end up in one of my Kís-probably my Flying Brick track bike.†
Iím also accumulating parts for a naked K special so it may end up in that too. Itís fate will be decided when I try the Flying Brick after rebuilding it when a cylinder head gasket failed †earlier this year. I took the opportunity to clean the ports up and polish all the valves so Iím hoping for a slight performance gain as there was lots of thick carbon everywhere inside the ports and on the valve heads.†
The only difference between the 1100 and 1200 motors I have is 100cc as the 1100 has 1200 cams, throttle bodies and oil cooler.†
I wonder what different the long stroke 1200 lump would have over my present 1200ised 1100?
