1Back to top Go down    K100RT Odometer not workingR on Wed Nov 01, 2017 11:03 pm
veets
I have a 1985 K100RT with 75000 miles on it and the Odometer stopped working after hauling it about 100 miles on a trailer. The speedometer is working fine but neither the trip nor the main odometer is working now.
Has anyone else come across this problem?
Veets
2Back to top Go down    Re: K100RT Odometer not workingR on Wed Nov 01, 2017 11:21 pm
A well known problem with these bikes.
The gears that drive the odometer age. They turn to mush. The teeth strip off and/or the gear disintegrates. Gears can be bought as a set and are relatively easy to replace.
Do a search for it on the Forum (Forum Google Search). There are instructions available on how todo the repair.
It has been advised by others that youdo not lube the gears when you replace them.
3Back to top Go down    Re: K100RT Odometer not workingR on Wed Nov 01, 2017 11:39 pm
veets
Thanks. I have found the gears at odometergears.com but I also read that it could be an electrical problem. Are there any easy checks before I have to tear it apart?
4Back to top Go down    Re: K100RT Odometer not workingR on Thu Nov 02, 2017 12:06 am
Veets, you need to have a visual inspection of the gears and to do that you need to remove the cluster from the bike and remove the back cover. Once apart it is easy to check each gear and ifany is broken/dead, it may be worth your while to replace all the gears. Electrical problems tend to hide in the connector plug at the back of the cluster, but it sure sounds like a mechanical gear problem.
1983 K100basic vin 0003960 colour red
1987 K100RT vin 0094685 colour, orange peel, sorry, pearl
5Back to top Go down    Re: K100RT Odometer not workingR on Thu Nov 02, 2017 5:39 am
I am inclined to think that because the speedometer is working the electrical drive is fine and its the gears need looking at. Usually the electrical problems if the happen kill the speedo as well as the odometer.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 87,050 miles
1983 K100RS 0011175 Fricka 29,000 miles Damn K Pox
6Back to top Go down    Re: K100RT Odometer not workingR on Thu Nov 02, 2017 8:28 am
veets
Thanks. I will take a look at the gears.
7Back to top Go down    Re: K100RT Odometer not workingR on Fri Nov 10, 2017 4:14 am
Andrew2
This might be of some help.
Andrew
8Back to top Go down    Re: K100RT Odometer not workingR on Fri Nov 10, 2017 6:34 am
td5
HI Veets,
I'd replace them all, as I had my one serviced which they replaced not all of the gears as the rest were fine, one year on you can guess what happened.
Mike
1988 / K100RS
2003 / R1150R
2015 / K1300R
9Back to top Go down    Re: K100RT Odometer not workingR on Sat Nov 11, 2017 11:36 pm
WoodyAUK75
That video is great. I'm going to change mine next winter. Does the speedo needle only go back on in one place? I changed some on a car once and it was slightly out forever more.
10Back to top Go down    Re: K100RT Odometer not workingR on Sat Nov 11, 2017 11:59 pm
@WoodyAUK75 wrote:That video is great. I'm going to change mine next winter. Does the speedo needle only go back on in one place?
You'll be able to align it where you want it then push it down onto the spindle.
1995 K75T 68,000 miles
11Back to top Go down    Re: K100RT Odometer not workingR on Sun Nov 12, 2017 6:55 am
Be careful when pushing the needle back on. The spindle is extremely thin and it's very easy to bend it. Before screwing everything back together, drop the assemblies in and ensure that the needle isn't fouling the transparent plastic because they will go on 'sideways'.
One last warning: the splines on the top of the spindle are crimped on. I have seen one needle come off with the splines still inside it. The fix for that was to put it back together with a tiny drop of superglue.
12Back to top Go down    Re: K100RT Odometer not workingR on Sun Nov 12, 2017 7:22 am
Apparently lubricating the gears with grease leads to them slowly turning to cheese. I bought new gears of Otto Instruments Brisbane and was told not to lubricate them.
13Back to top Go down    Re: K100RT Odometer not workingR on Sun Nov 12, 2017 6:34 pm
veets
Thanks guys. The videos and the watch-outs will come in handy when I receive the gears in the mail.
14Back to top Go down    Re: K100RT Odometer not workingR on Mon Nov 13, 2017 4:14 am
Andrew2
@WoodyAUK75 wrote:That video is great. I'm going to change mine next winter. Does the speedo needle only go back on in one place? I changed some on a car once and it was slightly out forever more.
Might pay to mark the needle position before you remove it and put it back in the same place.
1987 K100RS
