3 Re: Rear Shock Tue Oct 31, 2017 4:52 pm
WoodyAUK75
Judging by its position, I would say it is for draining or adding oil.
4 Re: Rear Shock Tue Oct 31, 2017 6:40 pm
BobT
No definitely an adjustable damping knob. Not possible to add oil to the bottom of a shock.WoodyAUK75 wrote:Judging by its position, I would say it is for draining or adding oil.
5 Re: Rear Shock Tue Oct 31, 2017 7:19 pm
Bob's right.
6 Re: Rear Shock Tue Oct 31, 2017 10:34 pm
JR_K100RS
has it been mounted upside down ? , my aftermarket shock is the other way around , remembering all that logic about unsprung weight etc , fix the heavier moving part to the frame , the lighter moving part to the wheel
John Re
Melbourne Australia
John Re
Melbourne Australia
7 Re: Rear Shock Wed Nov 01, 2017 1:29 am
Different brands of shocks have differing mounting positions. A Progressive 465 gets mounted piston upward. The K75 riders manual shows the stock shock mounted piston downward.JR_K100RS wrote:has it been mounted upside down ?
8 Re: Rear Shock Wed Nov 01, 2017 4:36 am
BobT
Unsprung weight! Your'e having a laugh. This is a BMW K100 with a wheel that weighs in at twice what my Ducati does, and a shaft drive that might as well be made of cast iron.
The popular RAM shock is almost identical to the one in the picture and is mounted that way up.
9 Thank you for the replies Wed Nov 01, 2017 2:04 pm
tagaz
Thanks to all who have replied.
I believe Bob is correct on this one.
I will experiment with turning it a bit each way and see what effect it has.
First must find the source of the fluid leak from the fd.
Troy
Troy
10 Re: Rear Shock Wed Nov 01, 2017 4:18 pm
Exactly!!!BobT wrote:Unsprung weight! Your'e having a laugh. This is a BMW K100 with a wheel that weighs in at twice what my Ducati does, and a shaft drive that might as well be made of cast iron.
11 Re: Rear Shock Wed Nov 01, 2017 6:55 pm
JR_K100RS
Ouch ! , er yup I was having a laugh !
John Re
Melbourne Australia
John Re
Melbourne Australia
12 Re: Rear Shock Sun Nov 26, 2017 5:10 pm
I think you will find that turning the knurled knob to the left (anti-clockwise) will deliver a slightly softer or slower feel to the ride and to the right a firmer, or quicker response. I usually make a large adjustment rather than small steps so I can more accurately gage what changes my adjustment has rendered. With small steps you might not feel much change at all.tagaz wrote:I will experiment with turning it a bit each way and see what effect it has.
Troy
1977 R75/7-100, '93 K11/K12 Big Block, '95 R100 Mystic, '96 K1100RS, '98 K1200RS, '06 K1200R & '09 K1300GT. Projects: 1993 & '96 K1100RS, & 1st '98 K1200RS.
Similar topics
