1Back to top Go down   Externally mounted fuel pump. Empty Externally mounted fuel pump. on Sun Nov 19, 2017 12:48 am
his might be a solution for inmates who wish to get away from the in tank mounted fuel pump. It would allow more scope for those wishing to pursue alternate and custom tanks. I've got no idea if it's any good so try at your own risk.https://www.aliexpress.com/item/OSIAS-Brand-new-aluminium-Direct-Fit-EFI-Inline-Electric-Fuel-Pump-E10009-for-BMW-Alfa-Romeo/32836446960.html?
Externally mounted fuel pump. Custom10
2Back to top Go down   Externally mounted fuel pump. Empty Re: Externally mounted fuel pump. on Sun Nov 19, 2017 6:41 pm
In general you can use any fuel pump externally. All you have to remember is that they are fuel-cooled, so running them without fuel will cause damage in a very short period of time.
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
3Back to top Go down   Externally mounted fuel pump. Empty Re: Externally mounted fuel pump. on Sun Nov 19, 2017 7:14 pm
In the ad it states frame mounted, there is a comprehensive list of the cars that it suits. However I'm not familiar with any of them, and I don't know whether any of them are externally mounted.
Noise Output: QUIET
Condition: 100% BRAND NEW
Design: Inline (Frame Mounted)
Minimum Voltage: 12V
Flow: 190LPH
Operating Pressure: 15-90 PSI - final fuel pressure set by regulator
4Back to top Go down   Externally mounted fuel pump. Empty Re: Externally mounted fuel pump. on Sun Nov 19, 2017 8:03 pm
If it is meant to be external then the flow of fuel is sufficient to cool them but not if it is meant to be internally mounted.
5Back to top Go down   Externally mounted fuel pump. Empty Re: Externally mounted fuel pump. on Mon Nov 20, 2017 6:40 pm
I have to admit, Rick, that most of my experience comes from Guzzis and in usual Guzzi style they use the same pump in and out of the tanks. Somewhere in one of the service manuals is that comment about the pumps being fuel-cooled. Stupidly, I thought it was applicable more widely.
