flyinglow
flyinglow
I have the fuel tank and air box removed on my 1985 K100RT so I thought I'd replace the clutch and throttle cables. I must be missing something easy because I don't see how to remove the clutch lever so I can remove the clutch cable. I screwed the adjuster in and removed the pivot screw but can't remove the lever so I can remove the cable? Thanks, jim
Dah! I didn't understand you need to remove the cable from the rear end clutch arm first to give enough slack for the front to be removed.
Last edited by flyinglow on Sat Dec 02, 2017 2:15 pm; edited 1 time in total (Reason for editing : Clicked check box for Notifications)
You've just been stuffed by one of BMW's "make this look neat and to hell with the easy maintenance" tricks. First move: put a towel or large rag on the floor under the handlebars. Not joking.
Release the cable from the gearbox end (if you haven't already done so) and push it through so that you've got lots of slack.
Pull the lever back to the handlebars and wriggle the cable so that the barrel in the lever comes out downwards.
If the barrel hasn't made a dash for freedom and been stopped by the towel, release it from the cable by sliding it along the cable until the nipple is visible. The barrel will now come gracefully off in your fingers/make another dash for freedom. The cable should now slide through the adjuster. There should be a small felt pad on the cable which lubricates the pivot but it's quite often missing.
When replacing the barrel, don't forget the towel! Very Happy Very Happy Very Happy
Oh - and one last point. When setting up the new cable be sure that you have the requisite 75mm between the gearbox clutch arm and the gearbox boss (see Clymer or similar). If you don't, clutch slip is guaranteed.
some good points dai
jim to remove the cable from the clutch arm at the back
perhaps a rag over the muffler near the foot peg plate , a long screwdriver and lever the clutch arm up so that the gland that fits in the fork of the arm can be released .
then there is adequate cable movement to play with removing the clutch lever stuff
hope that helps
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OHow to remove and replace clutch cable on K100RT Au-log10
Andrew2
Andrew2
I'm not sure if it's the same as a K75 but here's a video that might help.
1987 K100RS
Wossa cluth cable? Is it thpecific to a K75? How to remove and replace clutch cable on K100RT 723598
I understood there were two cables for Ks, long one for RT/LT, shorter one for RS and basic models.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now91,850 miles
1983 K100RS 0011175 Fricka 29,495 miles Damn K Pox
You're right. That was almost the first question Motorworks ever asked me - long or short cables.
8Back to top Go down   How to remove and replace clutch cable on K100RT Empty Clutch Cable Removal on Sat Dec 02, 2017 2:32 pm
flyinglow
flyinglow
Thanks for the replies. I did get the cable out, so now I'm waiting for a new cable to arrive. My cable did not have the little felt piece at the lever end, mentioned above, so hopefully the new one will. I also didn't know about the wave washer that pops out when the lever is removed. That little bugger went flying across the garage floor and hid, for quite some time, under a shelf.
And the towel was where..? How to remove and replace clutch cable on K100RT 44271
10Back to top Go down   How to remove and replace clutch cable on K100RT Empty clutch lever Towel on Sat Dec 02, 2017 4:34 pm
flyinglow
flyinglow
Yes, I did have a small towel but what I needed was more of a blanket size parts catcher. So, your recommendation was right on the mark.
