1Back to top Go down    Turn signal cancel inoperative on Sun Dec 17, 2017 11:24 am
webster
webster
85 rs--all original.
2Back to top Go down    Re: Turn signal cancel inoperative on Sun Dec 17, 2017 11:38 am
It's a bad connection. Disassemble and clean the right hand switch cluster.
2011 Moto Guzzi V7 Racer
3Back to top Go down    Re: Turn signal cancel inoperative on Sun Dec 17, 2017 4:55 pm
Also check the connector (under the tank) for this RHS switch assy.
Did you find out about the missing tail light?
If not, the problem could also be in this connector.
It should be a bridge between the grey/blue and white/yellow wire.
4Back to top Go down    Re: Turn signal cancel inoperative on Mon Dec 18, 2017 12:05 am
Remove the combination switch from the right hand grip and spray a good amount of DeoxIt in there. I just had the same problem back in October and cleaning the cancel switch fixed it. It was shocking how much dirt came out of it.
1994 K75S
1992 K100RS
