GF Wollongong
GF Wollongong
Finally made / found some time to put output staff back into motor.
Haynes and BMW both refer to using Three Bond 1110B or Loctite 273 between the main bearing outer race and the housing
I have neither. However I do have loctite blue and some grey RTV gasket sealant
Looking at pics of both the recommended items on the internet seems to show: Three Bond is like a gasket sealant while loctite seems to be the typical red thread locking fluid.
To me these would appear to be quite different products.
Anyone got experience on which one I should use?
I noticed that there is some marking on the housing - I assume from the bearing outer race moving in the past. I will ignore this and not replace it (as mentioned in the manual)
Guy
I would be using Loctite 609 we have come a long way since those books were written
http://www.loctite.com.au/3320_AUE_HTML.htm?nodeid=8802648195073
@RicK G wrote:I would be using Loctite 609 we have come a long way since those books were written or 641 if it is really loose.
Bit of a blast-from-the-past, that one. Three Bond 1110B is a bearing gap sealer, not the gasket cement we're all so fond of. It was the equivalent of the Loctite 273 but as Rick says, something more modern is called for.
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
GF Wollongong
GF Wollongong
Thanks for the replies, Gents.
Will get to the auto shop if one more search doesn't locate the red loctite I know is lurking in the shed somewhere.
Regards
Guy
