1Back to top Go down   Ngk spark plug threaded terminal Empty Ngk spark plug threaded terminal Tue Dec 26, 2017 10:15 pm
gabriel
Hi
I recently purchased four NGK D7EA spark plugs for my K100 1983 model.
The spark plugs have a threaded terminal.
Apparently there are adaptors available which can be screwed onto the terminal.
I can't source these parts.
My current spark plugs are Bosch.
I don't know what to do?
All suggestions are welcome and appreciated.
Enjoy your Christmas holiday.
Regards
Gabriel
2Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Tue Dec 26, 2017 10:34 pm
Contact NGK Australia and tell the tech support guy that you always use NGK plugs in all your engines, but these don't work with your K bike because of the missing Terminal Nut, and can you get a number of the nuts to install on your plugs.
I managed to get a dozen for free from NGK U.S.
3Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Wed Dec 27, 2017 3:20 am
Most small engine mower places will give you some if you approach them nicely. Chocolates or flowers will ease the way. Ngk spark plug threaded terminal 652573
4Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Wed Dec 27, 2017 1:23 pm
Or if you build enough Britbikes, you steal the terminal nuts off the existing plugs then replace both plugs and caps as part of the rebuild Ngk spark plug threaded terminal 652573
5Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Wed Dec 27, 2017 7:30 pm
I got a handfull of them when at the car wreckers, the 6 cyl Falcons seem to be the ones that have them.
6Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Thu Dec 28, 2017 3:59 am
KiwiK100
KiwiK100
Unscrew them off ya Bosch plugs and fit them to your NGK plugs.
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
7Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Thu Dec 28, 2017 4:22 am
KiwiK100 wrote:Unscrew them off ya Bosch plugs and fit them to your NGK plugs.
The recommended Bosch plugs (X5DC) don't have M4 threads but a solid SAE terminal.
8Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Thu Dec 28, 2017 4:56 am
KiwiK100
KiwiK100
Hmm, that'l make that idea a bit of a lost cause then Inge
Current rides:
The family history:
9Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Thu Dec 28, 2017 12:03 pm
gabriel
Hi
Thank you all for your suggestions.
I found a lawn mower repair business two blocks from my house and was given four terminal nuts.
I also sent a message to NGK Australia.
I installed the new spark plugs.
Didn’t notice any improvement Over the old ones.
I want to balance the throttle bodies but I lack the necessary skills and tools.
Regards
10Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Thu Dec 28, 2017 3:08 pm
Flowers or chocolates?? Ngk spark plug threaded terminal 44271
11Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Tue Jan 02, 2018 10:48 am
gabriel
Hi
Apologies for the late reply.
I gave the guy some pocket change which was approx $7.00.
A tad excessive but it was the Christmas holiday period.
12Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Tue Jan 02, 2018 2:31 pm
You can buy a Carbtune  Manometer for about $150.00 AU and it does up to 4 cylinders. Or point seven five may give his plans for his home made one.
13Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Tue Jan 02, 2018 4:06 pm
MartinW wrote:You can buy a Carbtune  Manometer for about $150.00 AU and it does up to 4 cylinders. Or point seven five may give his plans for his home made one.
Or, as I discovered recently, a friend with some nice 70s Honda 4s, seems he has been messing with Ks unbeknownst to me says they will do the job too. I used to have one of those, a CB500-4 and we always had our own gauges but never realised they would work on a K bike.
14Back to top Go down   Ngk spark plug threaded terminal Empty Re: Ngk spark plug threaded terminal Tue Jan 02, 2018 5:25 pm
Olaf!!! They're not motorcycle-specific (okay, so you just found that out Very Happy ). Even a single gauge can be used to balance four cylinders with a bit of mental gymnastics, a pencil and some paper (remember those? Not everybody will).
