1Back to top Go down   Members introduction Empty Members introduction Tue Jan 09, 2018 7:13 am
OneRunGun
OneRunGun
G'day from Ballarat, Victoria, Australia. I bought a 1984 K100RS about 6 months ago and are just in the process of getting it on the road. I have ridden my BSA M21 (1952) for the last 5 years so I will have to get used to a bike with the gear lever on the left, and the brake on the right. I will also have to get used to a bike that doesn't need to be kick started and one that goes faster than 47 miles an hour flat out. I hope to get a few miles out of the K100RS  over the next few years, but as a mechanic I make a good Shearer, so if i ask a few questions that may appear silly, forgive me. The first is what are the good oils to use in a 1984 bike in Australia? Thanks for having me in the Forum, Bernie.
2Back to top Go down   Members introduction Empty Re: Members introduction Tue Jan 09, 2018 8:14 am
welcome Bernie
there is lots of discussion about oils
for me up here in brissy  20 - 50  works well
a good option for further south could be the 15 - 40
traditionally mineral oils , but nothing wrong with the synthetic
have fun with the rs
3Back to top Go down   Members introduction Empty Re: Members introduction Tue Jan 09, 2018 8:21 am
Hi Ya Bernie good to have you on the forum.
With regards to oil, use the best oil you can justify buying.
I have been using Shell HX5 for many years and have had a good run but am gradually changing over to synthetic Penrite 10W 40 because the synthetic oil has a longer life and tolerates the extreme heat better.
There are lots of good oil out there and the only ones to avoid are the cheap home brand stuff from supermarkets which is usually re-manufactured from old oil collected by charities from workshops.
4Back to top Go down   Members introduction Empty Re: Members introduction Tue Jan 09, 2018 9:47 am
ERasberg
ERasberg
Welcome onboard Bernie!
I bought my RS in September last year, so fairly new myself. I live in France however.
For oil I run a mineral oil, which is what I can find at the nearest gas station. I currently run an engine oil meant for cars (ACTIVA 5000 15W-40), though many people have told me this is not smart and that I should run a motorcycle engine oil.
I use 15W-40 in the winter and 20W-50 in the summer. I have this habit due to my boxer engine bike that is oil-cooled, and has a prominent change in behaviour when the temperatures creep toward 30degC.
In my opinion many people don't pay enough attention to the oil's viscosity range. It's informative to look at the viscocity chart in the service manual.
Present
1988 K100 RS SE - VIN# 0146971K100RS - 105,000 km
1998 R1200C
1971 R75/5
Previous
1999 Virago XV125
1981 R65
5Back to top Go down   Members introduction Empty Re: Members introduction Tue Jan 09, 2018 11:35 am
For most motorcycles the advice would be to use motorcycle oil. That's because clutch and gearbox also share the engine oil.
But the K100 has a dry clutch and separate gearbox just like a car so it doesn't need motorcycle oil.
6Back to top Go down   Members introduction Empty Re: Members introduction Tue Jan 09, 2018 11:45 am
ERasberg
ERasberg
Thanks for that clarification Olaf ! Much appreciated.
Present
1998 R1200C
1971 R75/5
Previous
1999 Virago XV125
1981 R65
7Back to top Go down   Members introduction Empty Re: Members introduction Tue Jan 09, 2018 5:40 pm
(Oh,oh, another oil thread starting here)...
Welcome!  My machines(I have three) don't seem to mind running on heavy duty diesel engine oil.  Synthetic Shell Rotella T6 15W40.  I figure that if over the road trucks can run up to a million miles on it, it should work in my bikes.
I like to use Shell oil products because I am one of several million owners of the company.
8Back to top Go down   Members introduction Empty Re: Members introduction Tue Jan 09, 2018 8:32 pm
I use 20-50 mineral oil all season from 100ºF to 20ºF. My coldest riding days are few because gravel road riding becomes unattractive when the roads turn slimy just before freeze-up.
9Back to top Go down   Members introduction Empty Re: Members introduction Tue Jan 09, 2018 9:30 pm
Andrew2
Andrew2
Welcome mate.
   I'll be using Delo 400 in my next change. The motor being a seperate unit from the clutch means a dedicated motorcycle oil isn't really needed. If it was you could still use a car oil as long as it doesn't have friction modifiers in it which most don't anymore. Plus Delo can be found in ant Caltex servo if needed.
 Andrew
1987 K100RS
10Back to top Go down   Members introduction Empty Re: Members introduction Thu Jan 11, 2018 8:35 am
Barry in IN
Barry in IN
Welcome, Bernie!
