1 Valves for Rims Sat Feb 24, 2018 7:34 pm
DBRMN
Hey guys does anyone know the best place to get valves for my rims (1991 BMW K100LT ABS) as my local tire places doesn't have the right ones.
DBRMN
DBRMN
Last edited by Two Wheels Better on Sat Feb 24, 2018 7:56 pm; edited 4 times in total
Two Wheels Better wrote:36 31 7 653 064 is the BMW part number, but any 15mm-wide base rubber or metal valve stem will work on BMW Y-spoke and three spoke wheels. Real Oem and Max BMW online show them retailing for about $9.00 USD each.
That is like saying do not buy a K100 because I had one break down! One split valve does not make a trend or an epidemic.MartinW wrote:Do not use the rubber pull through right angle ones. I had one split at the rim resulting in rapid air loss on the highway.
Actually, I mirrored Martin's experience so his is not an isolated case, I had the mechanic fit pull-through right angle valves on my K75 rims and both failed at speed, albeit only slowly leaking air. I now only use all-metal short straight valves.BobT wrote:That is like saying do not buy a K100 because I had one break down! One split valve does not make a trend or an epidemic.MartinW wrote:Do not use the rubber pull through right angle ones. I had one split at the rim resulting in rapid air loss on the highway.
Now it's an epidemic.robmack wrote:Actually, I mirrored Martin's experience so his is not an isolated case, I had the mechanic fit pull-through right angle valves on my K75 rims and both failed at speed, albeit only slowly leaking air. I now only use all-metal short straight valves.BobT wrote:That is like saying do not buy a K100 because I had one break down! One split valve does not make a trend or an epidemic.MartinW wrote:Do not use the rubber pull through right angle ones. I had one split at the rim resulting in rapid air loss on the highway.
K100-forum.com » Technical, repair and troubleshooting » Frame, fairing and wheels » Valves for Rims
Similar topics
