1Back to top Go down   K75 and K100 parts for sale Empty K75 and K100 parts for sale on Mon Mar 05, 2018 2:16 am
Current situation requires that I reduce the quantity of stuff I have accumulating around the house and garage.  To that end I am offering up a quantity of spare parts for sale at what I hope are prices that can't be refused.
Everything is clean, been checked to be good, and is ready to use.
I am willing to ship internationally, but to help control postage costs would ask that I be able to combine items for distribution at the destination.  My goal is make my stuff a good deal even if it has to travel half way around the globe.
Some of the stuff I have:
3 ea. Gear position indicator circuit boards.  2 have good LCD displays, the third only has the neutral output for the starter.  $35US for good LCD, $15US for board with neutral output only.
1ea. clock module converted to 12 hour US time.  $40US
1ea. MPH speedo for Motronic equipped K bikes.  Good faceplate and gears.  If desired, I will reset odometer to whatever you wish.  $40US
1ea. Odometer and tripmeter.  Good gears and number wheels.  $20US
1ea. K75 clutch friction disc.  Almost new, 5.3mm thick.  $35US
1ea. left handle bar assembly for K75/K100 with combination switch and clutch/choke.  $40US
1ea. 4 spoke rear wheel center hub cover with BMW roundel.  $10US
1ea. set of parts to replace K75 timing chain.  Lightly worn chain vitually the same as new, tensioner, and unworn chain guides.  $35US
1ea. K75 engine wiring harness.  $15US
1ea. Temperature gauge.  Bezel around glass is dented, but gauge works.  $10US
1ea. Tachometer movement for Motronic equipped bikes.  Includes good faceplate and pointer.  $20US
Email me for photos.  I hope the prices are attractive.  If not, don't hesitate to make an offer.
2Back to top Go down   K75 and K100 parts for sale Empty Re: K75 and K100 parts for sale on Fri Apr 20, 2018 3:45 am
gabriel
Hi
I’m interested in the left hand bar with combination switch.
Can you Plrase post a photo?
Gabriel
;BMW; 1984 BMW k100..frame number 6228?
3Back to top Go down   K75 and K100 parts for sale Empty Re: K75 and K100 parts for sale on Fri Apr 20, 2018 10:27 am
Woodie
Woodie
Well as luck would have it I'm trying to build up my stock of spares Very Happy.  I'll go for the center hub cover and the temperature gauge.  I can even pick them up if that works well for you.
Cheers, Andrew
1985 K100RT
52667
4Back to top Go down   K75 and K100 parts for sale Empty Re: K75 and K100 parts for sale on Fri Apr 20, 2018 10:54 pm
@Woodie wrote:Well as luck would have it I'm trying to build up my stock of spares Very Happy.  I'll go for the center hub cover and the temperature gauge.  I can even pick them up if that works well for you.
Cheers, Andrew
PM sent.
