Go to page : 1, 2, 3, 4, 5  Next
View previous topic View next topic Go down  Message [Page 1 of 5]
1Back to top Go down   K75kforkurz Empty K75kforkurz on Tue Mar 06, 2018 6:44 pm
chris846
chris846
Oddly enough, I couldn't find too many motorbike quotes from Mark Twain, or Abraham Lincoln, or even Shakespeare. So we'll have to go with some Irishman (you know who you are) who said...
"I once ran out of bikes to build. I couldn't believe the sense of panic"
Which pretty much explains why these are suddenly in the boot of my car
K75kforkurz 00313
Oh lord, why two?
The Longest Lunch
2Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 06, 2018 7:45 pm
Well, if you leave them alone for long enough, they might mate and multiply (if you're lucky....)
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
3Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 06, 2018 11:17 pm
Why Two? Well at a guess and seeing as you're quoting Irishmen, I'd say "to be sure to be sure" Might be the reason.  Very Happy
4Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 06, 2018 11:39 pm
Looks like the Dai is cast. I sense a Kwadricycle coming on. Inspired by one Madass.
5Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 07, 2018 8:55 am
chris846
chris846
Oh heck no,
It's happening again...
K75kforkurz 00815
K75kforkurz Krays13
The Longest Lunch
6Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 07, 2018 9:32 am
Chocolate
Chocolate
Love that :-)
7Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Sun Mar 18, 2018 8:54 pm
chris846
chris846
Just trying things for size and no, a 3 cylinder engine doesn't fit in a 4 cylinder frame (never take anyone's word for anything)
K75kforkurz 01311
I measured the paralever and standard swingarms with a bit more accuracy, and the paralever on its own adds 37mm to the wheelbase (the paralever is fitted in the picture)
Ignore the wheel in the pic (a 17" with a Tourance tyre) it's just there to give an idea of proportions.
K75cster noted the effect that a 78mm cut and shut would have on the alignment of the frame top rails (great spatial perception - I bet he's left handed!), so I checked this out. The slope is 7.5' and the missing 78mm would leave the back half 10mm lower than the front half. This would require the two halves each to rotate clockwise approximately 1' in order for them to align and be joined back up. Too much. Loses the benefit of the steeper rake.
Anyway, have a look at this:
K75kforkurz 00911
... which just cries out for a shapely hanger bracket cum rearset footrest mount, picking up the original M10 mounting hole and the 2 rearmost M8 footrest hanger holes. Guiding light is coming in through the window at this point because...this makes it possible to set the frame rear mountings 10mm higher than standard (it's set like that in the picture) which gives a further one degree reduction in rake. The two hanger brackets can be complemented with a triangular ally plate for the top bellhousing mounting, which will replace the original steel flange, replaced with a couple of bosses welded to the frame in its place. The 3 hanger plates can be remade with slighty different vertical offsets, which would be almost like having adjustable rake.
The reduction in rake to 25.5' now calculates out at 110mm trail using the KTM duke yokes and forks (34mm offset compared with 56mm offset on the standard K1100 yokes).
The wheelbase starting point is 1565mm (standard K1100RS). The 'forward shift' of the CDS by the missing cylinder is 78mm, which means that the rear wheel has moved forward by that amount. This stage brings wheelbase down to 1487mm. The increase in trail through using KTM yokes is 18mm (I can't find a web figure for the K1100RS' trail, so I calculated it at 92mm), so this rearward shift of the front wheel brings the wheelbase down to 1469mm. Lastly, the 1' increase in rake (calculated as a rotation of the frame around the front engine mounting) brings the front wheel back a further 3mm. So the theoretical wheelbase is down to 1466mm.
Just thoughts at this stage...don't shoot me
The Longest Lunch
8Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Sun Mar 18, 2018 9:12 pm
Post 5 has to be "Post of the Year"...if we had such a thing! Laughing
9Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Sun Mar 18, 2018 9:29 pm
chris846
chris846
Not sure that anyone outside the UK (or under 50) would know who those two guys are..
The Longest Lunch
10Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Sun Mar 18, 2018 10:05 pm
@chris846 wrote:Not sure that anyone outside the UK (or under 50) would know who those two guys are..
I am over 50, and from outside the UK. You got me on this one. Embarassed
K75kforkurz Frog15K75kforkurz Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
11Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Sun Mar 18, 2018 10:06 pm
Krayzy!
1995 K75 73,000 miles
K75kforkurz Usa-lo10
12Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Sun Mar 18, 2018 11:52 pm
If you want a good productive challenge put a 6 speed K1200 gearbox into the K75 and give us a step by step on the whole process or put a telelever front end on a K75.
They would be good projects and many here could benefit from what you do.
13Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 12:30 am
The Kray twins...Ronnie and Reggie. There are numerous books and a couple of films about the "exploits".
They had led an interesting life.
14Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 1:58 am
There are indeed quite a few who would like to see a K1200 gearbox in there......including one Michael Oakes and we know you know him too.
Speaking of strangers in the night a high res photo of K bikes was requested and one of your Kreation should be provided since you are coming to K Fest.
15Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 5:46 am
Interesting that you know I'm left handed, just from that one post, intriguing. Smile
I must say the frame seems to fit alright, I see you have the first two bolts in ready, Just three more to go.
A way to resolve the rotation of the frame is to sleeve and pin the upper frame rails together and then remove the 10mm from the legs accounting for the slight realignment of the front frame mounts, which may mean you gain a mm or two up top but you've only pinned them and they can be repined before welding and setting in position. That way the three rear bolts will slip right into the three mounts as yet lined up.
You can continue the way you are going with some attention paid to the rear wheels movement into the frame crossmembers.
The addition of 37mm by using the K1100 paralever nearly lines it all back up again in the 1100 frame just 41mm to sort.
Moving the engine forward to the front frame mounts and dragging the gearbox forward will change the stock footpeg setup, It would be close to a mid mount of forward controls like some choppers offer. Interesting concept.
I don't know anything about the KTM front end you are looking at but am wondering does the front guard look like touching the engine on full compression?
I like the idea of a K1200 gearbox and suspension in there, but thought it might work better with an R850rt gearbox and suspension, that would also give a closer final ratio for the road. The travel is 135mm for the R850 and that would match the front of a stock K1100 but maybe not the KTM or DUKE front end planned.
I at present have the K100 final drive on my K75, and it does not hurt the bikes drive out of corners of tootling around town. Just a thought.
Looking forwards to your next post. Interesting that the K1200 and R1100/850's have 120mm front end travel which is an equal to the stock K1100 rear in there at present. I am wondering just how a matched set of suspension travel would do to the bikes feel on the road.
16Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 7:07 am
chris846
chris846
"I don't know anything about the KTM front end you are looking at but am wondering does the front guard look like touching the engine on full compression?"
Good point, especially with the increased trail. That's what I'll look at today.
The K1200 gearbox leaves me without swingarm mounts. If it were shorter than the steel-frame gearbox then there might be room to locate the swingarm mounts in roughly the same place, but with the pivot studs mounted in the hanger plates. The K1200 bellhousing could be adapted to provide a fifth frame mounting - which I'd guess is necessary to keep the steel frame from flexing.
Does it make sense to put the K1200 ratios onto a 750?
The Longest Lunch
17Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 7:25 am
chris846
chris846
Here's some food for thought:
K75kforkurz 001_311
This is a R1100/1150 series swingarm and it seems to fit okay. Only thing is, the boxers have much shorter engines than the Ks so their swingarms are all a couple of inches longer. Shame, it would have offered a central shock.
The Longest Lunch
18Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 8:56 pm
chris846
chris846
K75kforkurz Stefan13 K75kforkurz Teleph16  Allo, Josef?
K75kforkurz Josef10 K75kforkurz Teleph12  Ja!
K75kforkurz Stefan11 K75kforkurz Teleph13  Listen up, der idiot from Barnsley ist at it again!
K75kforkurz Josef11 K75kforkurz Teleph14  Oh shitz...das is nicht true?
K75kforkurz Stefan12 K75kforkurz Teleph15  Mein freund, das ist nicht something Ich would pull your bein about. Listen, diese time wir haben to do something about it. Schnell. Haben sie still got das Mauser?
The Longest Lunch
19Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 9:02 pm
K75kforkurz 44271 K75kforkurz 44271 K75kforkurz 723598 K75kforkurz 112350
20Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 9:19 pm
Nein. Kalashnikov und Corbin.
21Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 10:33 pm
K75kforkurz Index10
22Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 10:42 pm
@RicK G wrote:K75kforkurz Index10
What kind of tyres do you recommend for your tank? Do you use mineral or synthetic oil? Does it play 10cc?
23Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 10:49 pm
Tyres:- Round Black rubberish,   Oil:- F**king heaps any kind including used from fish and chip shops,  No, it plays Burning Bridges.
24Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 19, 2018 11:36 pm
@RicK G wrote:No, it plays Burning Bridges.
Yeah - and everything's probably Obscured By Clouds when you've finished.
25Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 20, 2018 3:28 am
@chris846 wrote:Here's some food for thought:
K75kforkurz 001_311
I had suggested the 850 for the shorter gearing in the final drive, but which ever is used its the ability to line up with the stock rear guard that then allow you to have the short engined K75 motor and the R1100 gearbox final drive combo working in a frame you didn't have to amend. If it works then you would sit back rather smugly and feel really happy about your search for a great handling bike. 135mm front end travel on the stock 1100 forks and 135mm travel on the R1100 rear suspension, gotta be a great scoot to hoot about on.
26Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 26, 2018 7:26 pm
chris846
chris846
Early days, lots and LOTS of squinting required..
K75kforkurz 03810
Note No.1 tool centre stage..
The Longest Lunch
27Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Mon Mar 26, 2018 7:44 pm
chris846
chris846
K75kforkurz Stefan14 K75kforkurz Teleph17  Josef?
K75kforkurz Josef12 K75kforkurz Teleph18  Steffi liebling
K75kforkurz Stefan15 K75kforkurz Teleph19  Der Idiot ist "Skvinting" jetzt
K75kforkurz Josef13 K75kforkurz Teleph20  Sodding idiot.
K75kforkurz Stefan16 K75kforkurz Teleph21  Er hat gone and tried to put ein 3 cylinder engine into ein four cylinder frame!
K75kforkurz Josef14 K75kforkurz Teleph22  Ho ho ho ho ho...nicht wunder er ist...ho ho ho.."Skvinting"! Was ist los - kann er nicht count? Drei?...Vier? Ist he some special kind of moron? Ho ho ho ho
K75kforkurz Stefan17 K75kforkurz Teleph22  Nein, er ist from Barnsley. Sie sind all like das over there.
The Longest Lunch
28Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 27, 2018 1:32 am
Woodie
Woodie
Chris, es ist wunderbar!  I like how it levels out with the delicate earlier Y rim on the front which is then counterbalanced by the more meaty later 3 spoke on the back.  This will be a work of art that communicates on so many levels
1985 K100RT
52667
29Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 27, 2018 7:00 am
chris846
chris846
Listen 'Woodie', I have my limits you know, I can only take so much!
I'd say it looks worse in the flesh, but that's not possible. I think the key element that this project needs in order to proceed, is a lack of respect for reality.
The Longest Lunch
30Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 27, 2018 7:29 am
like the disks on the front chris ,what are they off ,  or newbies ?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OK75kforkurz Au-log10
31Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 27, 2018 8:34 am
chris846
chris846
Oooh good spot!
They are 310mm from a Soozooki (possibly early 18" wheel GSXR-1100) They needed drilling with a 4-hole pattern, plus a spacer. I fitted them to my K100 years ago.
I think other people have fitted these discs too?
Last edited by chris846 on Wed Aug 14, 2019 10:31 am; edited 2 times in total (Reason for editing : more info)
The Longest Lunch
32Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Tue Mar 27, 2018 9:25 am
K75kforkurz 112350
33Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 28, 2018 3:25 am
Barry in IN
Barry in IN
OK, I'm going to have to say this again.  I don't care much for custom conglomerations, but based on your last example, I'm looking forward to this.   It should be a great mix.   Sort of a "Best of K Bikes", or "K's Greatest Hits".
 Everything you ever wanted in a BMW...and less.
34Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 28, 2018 6:11 am
club_c
club_c
Post 7. I know those are English words but cannot understand a syllable of it...
1988 K100RS SE VIN 01477554
35Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 28, 2018 8:43 pm
chris846
chris846
"Post 7. I know those are English words but cannot understand a syllable of it..."
That's because it's garbled nonsense masquerading as technical insight. I mean, c'mon, that last picture just looks like the kids have been playing with bike parts.
On a serious note (now I'm laughing) I think K75cster's idea of removing 10mm or so from the front frame legs looks favourite. The radiator will still just about fit, and the measured rake (26') will be preserved. The KTM forks and yokes, with their increased trail, don't look like they are going to cause problems with the front wheel striking the timing cover. But, the steering lock seems as though it might be a bit limited. I say a bit limited...I'll probably rip the tyres off and travel everywhere by railway lines.
The Longest Lunch
36Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 28, 2018 8:50 pm
chris846
chris846
K75kforkurz Stefan18 K75kforkurz Teleph23  Allo Casey?
K75kforkurz Casey_10 K75kforkurz Teleph23  Steamin and a rollin' baby, steamin and a rollin...
The Longest Lunch
37Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 28, 2018 9:20 pm
@chris846 wrote:"Post 7. I know those are English words but cannot understand a syllable of it..."
Sounds like your on the right track.
Reminds me I have this nice Bob Dylan album here....
38Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 28, 2018 9:26 pm
chris846
chris846
Well this is definitely looking like one slow train, turns out I promised to do some decorating when I retired 15 months ago. How can anyone remember that? I can't even remember what I had for tea last night
The Longest Lunch
39Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Wed Mar 28, 2018 10:05 pm
@chris846 wrote:Well this is definitely looking like one slow train, turns out I promised to do some decorating when I retired 15 months ago. How can anyone remember that? I can't even remember what I had for tea last night
I was thinking more like 'Blood on The Tracks'.....
Sounds like we need to dig out 'Paint it Black'.
40Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Thu Mar 29, 2018 4:52 pm
chris846
chris846
"I see a red door and I want to paint it magnolia.."
Nah, it wouldn't have worked.
The Longest Lunch
41Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Fri Apr 06, 2018 8:57 pm
chris846
chris846
Still squinting. Seat arrived from cafe4racer, very impressed. Note that there's actually 2 (one's upside down on the bench) the first arrived damaged in transit - the second arrived just 36 hours later! Excellent people.
I'll post some details of the seat unit later, but meanwhile I'm just playing with the lines before I start sawing things to bits. I'm thinking of an Avon/Rickman fairing - the one with the big perspex nosecone. The tape line between the forks and the tank is the bottom edge of the fairing..
K75kforkurz 00414
The Longest Lunch
42Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Fri Apr 06, 2018 9:07 pm
chris846
chris846
K75kforkurz Stefan20 K75kforkurz Teleph24  Ist das...insulation
K75kforkurz Josef16 K75kforkurz Teleph24  ...tape?
K75kforkurz Stefan21 K75kforkurz Teleph25  .....
K75kforkurz Stefan20 K75kforkurz Teleph24  Fritzi...
K75kforkurz Josef16 K75kforkurz Teleph24  Steffi...
K75kforkurz Stefan20 K75kforkurz Teleph24  Ach, mein mutti..
K75kforkurz Josef16 K75kforkurz Teleph24  Julie Andrews?
K75kforkurz Stefan20 K75kforkurz Teleph24  MEIN MUTTI IST NICHT JULIE ANDREWS!
K75kforkurz Josef16 K75kforkurz Teleph24  Sie sind from Austria nicht wahr?
K75kforkurz Stefan20 K75kforkurz Teleph24  Ich bin nicht ein bloody Von Trapp for der millionth time, you sodding imbecile!
K75kforkurz Josef16 K75kforkurz Teleph24  Edelweiss...edelwiess...
The Longest Lunch
43Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Fri Apr 06, 2018 9:12 pm
@chris846 wrote:Still squinting. Seat arrived from cafe4racer, very impressed. Note that there's actually 2 (one's upside down on the bench) the first arrived damaged in transit - the second arrived just 36 hours later! Excellent people.
K75kforkurz 00414
Funny how BMW designed that tank over 30 years ago with holes in it for you to set out your fairing lines.
I knew the K was ahead of its time but that puts a new perspective on it.
I guess now you will find the Rickman fairing is a perfect fit.....
44Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Fri Apr 06, 2018 9:29 pm
chris846
chris846
K75kforkurz Stefan22 K75kforkurz Teleph26  Pretty smart huh, die holes in der tank fur die Rickman fairing?
K75kforkurz Josef18 K75kforkurz Teleph26  Das was my idea.
K75kforkurz Stefan22 K75kforkurz Teleph26  Das sodding was not. Your idea was der side panels das kept falling off!
The Longest Lunch
45Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Fri Apr 06, 2018 10:26 pm
Hier ist Fritz Egli.....Side panels??? Nein!!!!!!
46Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Fri Apr 06, 2018 10:31 pm
It looks like the tank needs to drop at the rear to align with the fairing tape line. Just visualising and thinking. That would create a lot of work to true the image. But the Image would run so clean that way.
The other thing I am wondering it the seat tank relationship, will they partner for life or completely marry?
Just looking at the shape of the seat front and imagining the tank shaped the same, a real orgasmicly close fit to us humans
I can see why you wanted the R1100 gearbox and suspension, that combo would really look good huh?
47Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Sat Apr 07, 2018 12:21 am
agree about the tank line
what about raising the front of the tank just a metric smidgen (maybe 30 -50mm )  pending interference from the steering head ?
48Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Thu Apr 12, 2018 8:14 pm
chris846
chris846
Trying to organise the lines...
K75kforkurz K75k510
...to put me in touching distance of the most achingly gorgeous bike of all time, that I'll never own...
K75kforkurz Honda-10
The Longest Lunch
49Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Thu Apr 12, 2018 9:53 pm
Burgh... it's Japanese (says the Bandit owner!).
50Back to top Go down   K75kforkurz Empty Re: K75kforkurz on Sun Apr 15, 2018 9:24 am
As far as Zorst's go I'd bet parts of your anatomy would twitch if you were to run a three into two and Siamese it up under the tail piece like the V twin Honda's did.
Wont all those lines weight the bike down?
View previous topic View next topic Back to top  Message [Page 1 of 5]
