1Back to top Go down   No spark with plugs on motor Empty No spark with plugs on motor Sun Sep 23, 2018 4:11 pm
Newby
Newby
Hi guys i need some advise please i have a k100 83 model i have spark when i hold the plug about 5mm away from the body but when i put the plug against the body there is no spark i changed plugs and leads please any advise
2Back to top Go down   No spark with plugs on motor Empty Re: No spark with plugs on motor Sun Sep 23, 2018 5:43 pm
Perhaps the administrator can delete this question from Forum Functionality or perhaps merge it with the appropriate subject?
A gentle reminder to all Introduced Members to please post in the right section of the forum.
Thanks.
3Back to top Go down   No spark with plugs on motor Empty Re: No spark with plugs on motor Mon Sep 24, 2018 1:28 am
Newby
Newby
Sorry about this i am in S.A and the guys here are of little to no help
4Back to top Go down   No spark with plugs on motor Empty Re: No spark with plugs on motor Sat Sep 29, 2018 1:32 pm
Two Wheels Better wrote:Perhaps the administrator can delete this question from Forum Functionality or perhaps merge it with the appropriate subject?
Thanks.
Thanks TWB.
The topic has been moved.
No spark with plugs on motor Frog15No spark with plugs on motor Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   No spark with plugs on motor Empty Re: No spark with plugs on motor Sat Sep 29, 2018 9:11 pm
Newby wrote:Hi guys i need some advise please i have a k100 83 model i have spark when i hold the plug about 5mm away from the body but when i put the plug against the body there is no spark i changed plugs and leads please any advise
This sort of thing can be an indication of bad coils. Check continuity of the primary and secondary windings and that there is no connection with the centre core of the coil from either winding. Being an 83 model it still may have the old grey/black coils which were known for giving trouble.
