1Back to top Go down   Centre stand Empty Centre stand on Mon Mar 19, 2018 6:19 pm
Davep
Davep
Hi All,
I need to replace the centre stand on my 1983 rs, I let this one go as it's from a 1990 and is different. The 83 one has big curves where as this one seems to have feet.
https://www.ebay.co.uk/itm/BMW-k100rs-stand-assembly-/332583070819?ul_noapp=true&nma=true&si=yZg%252FVDMoXc5fG6CfqejU%252FQ%252BG648%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Have I missed a chance here or was I right to let it pass? And if so what other centre stands will fit without too much modification?
Thanks in advance.
Dave
Centre stand Eu-log10 BMW K100RS 1983 (Main ride)
                      Suzuki GSX 750 ET 1979 (Needs work)
                      Kawasaki Zephyr 750 1992 (Needs hiding)
2Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 6:21 pm
I put a complete K1100 assembly on my 84 K100RT. Straight swap once you have the complete assembly. I struck lucky with a good one off a 16k mile bike and it looked it.
Your linked eBay post is deleted as the item has ended.
Try this one, in Sherlocks where I got mine. Excellent to deal with.
https://www.ebay.co.uk/itm/BMW-K100RS-16V-1990-24-259-miles-complete-centre-main-side-prop-stand-assembly/183093266942?hash=item2aa13589fe:g:gKAAAOSwZQRYbRbt
There are others on eBay coming from Germany too.
3Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 6:23 pm
Yes, you blew it.  Those K1100 stands are a direct bolt up to the earlier bricks.  Not only are they less likely to rust out and drop your bike, but they are easier to get the bike up onto the stand.
Keep watching, another one will be along sooner or later.
4Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 6:31 pm
@Point-Seven-five wrote:Yes, you blew it.  Those K1100 stands are a direct bolt up to the earlier bricks.  Not only are they less likely to rust out and drop your bike, but they are easier to get the bike up onto the stand.
While they are less likely to rust out and drop your bike, the fact that the feet are much smaller means that if parked on ground rather than concrete/tarmac, and rain softens the ground, the right foot sinks into the ground and drops your bike.
The dent in my tank is the direct result.  affraid
5Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 6:37 pm
Before replacing the stand on my RT, every time I was greasing the splines, I was removing the rubber plugs on the centre stand and filled it with a mixture of hot oil and wax. I never had a problem.
Now I am a bit older and use the sidecar as the centre stand. Believe me, it works! Centre stand 261959
Centre stand Frog15Centre stand Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 6:37 pm
You need Kpucks. I keep one in my fairing pocket. Seen it happen too.
7Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 6:41 pm
@Crazy Frog wrote:Before replacing the stand on my RT, every time I was greasing the splines, I was removing the rubber plugs on the centre stand and filled it with a mixture of hot oil and wax. I never had a problem.
mmm....tried googling 'K rubber plugs, hot oil and wax' hoping it might throw up something like Sidecar Willie. Doesn't!
8Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 7:08 pm
I am perfectly aware that oil and rubbers sometimes don't mix well together but...
The cost of 2 rubber plus vs the cost of replacing a fairing and a centre stand is minimal.
These rubber plugs have a tiny little hole in their center and it's imperative to keep it clean (Any accumulated water/moisture will drip from there) This is basically the same as the drip hole for the oil/water pump.
9Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 7:45 pm
Centre stand 44271 Centre stand 44271 Centre stand 44271 Centre stand 44271 Centre stand 44271 Centre stand 44271 Centre stand 44271 Centre stand 44271 Centre stand 44271 Centre stand 44271
Now I finally see why a Corbin seat has a hollow in the middle.......
10Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 9:13 pm
Every couple of years or so I remove the bungs and fill my stand with LPS Hard Coat Corrosion Inhibitor and let it sit for a while, then drain into a separate container. Mark the container and just keep on using it for the stand. Esso uses it under the name of LPS 3 offshore in Bass Strait. As far as soft ground I only use the side stand in conjunction with a 5" square galvanized post cap. To aid recovery attach a string to it, pull the string in and ride to a firm spot and stow the cap. The cap is multi purpose, a place to put small parts while working on the bike, ash tray, water dish for your dog,  donation container when trying to raise money by singing, finger bowl after chicken wings.
11Back to top Go down   Centre stand Empty Re: Centre stand on Mon Mar 19, 2018 10:42 pm
JR_K100RS
JR_K100RS
Another advantage of the later stand Dave is if you ever decide to fit a wider rear wheel ( from a 16V K100 or a K1100 ) at 4.5x18 inch the later stand will accept it with minor mods whereas the older stand will not
John Re
Melbourne Australia
12Back to top Go down   Centre stand Empty Re: Centre stand on Tue Mar 20, 2018 12:37 am
@Davep wrote:Hi All,
Thanks in advance.
Dave
Grab it dave it is a much better stand
