1Back to top Go down   I stuff up !!! Empty I stuff up !!! on Sat Mar 24, 2018 2:43 am
Hello all
I stuffed up
When replacing the GPI i put the battery back in to test it working correctly
And because the bike has been on the work bench i had the battery on trickel charge
Knowing that the bike has turned over in a little while i thought might as well give it a turn over seeing that the battery just sitting in the bike
But i forgot to disconnect the the trickel charger
All light came on then something went pop
And all lights are gone
Dic
Sconnect the trickel charger and turn the switch i get nothing now
Thinking i have done a relay under the tank ?
All the fuse on the side are ok
2Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 4:21 am
Do you have any power at the battery? You may have fried it.
https://www.cartalk.com/content/several-months-ago-i-was-having-some-difficulty-my
I stuff up !!! Frog15I stuff up !!! Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 4:33 am
Gone for a beer
Still kicking my self for doing something so silly
Well two step back today
This and struggling with removing a rear disk
 hopefully tomrrow i can get back to were i started before i screwd everthing i did today
I think it more likley a cooked rely problem
Finger crossed
4Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 5:13 am
Matt if you have rounded out the hex in the screws that hold the disc on get a 5/16 drill bit and drill the head off the screw and the disc will come away. To get the remainder out try welding a piece of rod to the stub and the heat will often make the red Loctite let go or just use a fine heating tip and heat the stub of the screw and try a set of vicegrips on it.
5Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 5:36 am
Started to round out the head but not fully yet
So down tools and have a beer hopefully a new day new luck
6Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 8:10 am
Stumpy
Stumpy
@Matthew-Brisbane wrote:Started to round out the head but not fully yet
Use a hammer and hit it hard, it should break the binding caused by the locking compound.
7Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 8:42 am
On those two screws giving it a good clout with a hammer does nothing (been there done it) as the Red Loctite is used and they need heat, about 130°C to melt the stuff and the screws will come out, then use some throttle body cleaner or acetone to get rid of the red stuff and use nothing just tighten the screws to finger tight.  They cant come lose because the wheel stops them coming out. Why the hell that red stuff was used I don't know.
8Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 11:07 am
Rather than welding a bit of rod to the stubs, try filing a couple of parallel flats to take a 6mm or 7mm spanner. Worked for me.
9Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 3:20 pm
@RicK G wrote:Why the hell that red stuff was used I don't know.
Lawyers see red?
1977 R75/7-R100 grey, '87 K100RS red, '93 K11-K12 aka 'Big Block' black, '96 K1100RS black, '98 K1200RS red, '09 K1300GT red, & 2013 R1200RT-Polizia black & white.
10Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sat Mar 24, 2018 3:20 pm
Lawyers see red?
11Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sun Mar 25, 2018 1:19 am
Well I fixed the first of my stuff up which a
Was the electrics
I pop open the starter relay and load shed relay to make sure that they were not weld shut and ok to operate
This seem to fixed the first problem
The second was the screws I have ended up breaking the screw after drilling the head off
Then drill a small hole to belt a torx bit into it
Ended up breaking the torx bit off at the neck inside the bolt inside the final drive
It a bit like the old nursery song
12Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sun Mar 25, 2018 7:50 am
That just leaves spark erosion... at this point I suspect it's going to be cheaper to source a new drivebox.
13Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sun Mar 25, 2018 5:54 pm
Will hellcoils work in a the casting ?
14Back to top Go down   I stuff up !!! Empty Re: I stuff up !!! on Sun Mar 25, 2018 6:06 pm
In theory, yes. I've only ever put them in aluminium (cast and rolled/extruded).
