LFB goes to the Garage on Mon Mar 26, 2018 8:17 am
I was finally forced into a clutch change recently because as the clutch slip was so bad I could have been riding a moped insofar as acceleration was concerned. Stripping the backend of the bike to drop the gearbox off revealed the usual peeling paint but also something far worse; a shedload of rust under the paint. Additionally, the brackets that hold the Z-frames and mudguard were so badly spalled with rust that they weren't going to survive cleaning up. The two small additional brackets that go on top of them just fell apart. I really didn't like the look of the rust and just briefly I considered replacing the rear frame loop with a new one, but then decided I could probably cut the old brackets off with a bit of care. Assuming, that is, the main frame wasn't quite as bad as it looked.
Things got left that way for a few weeks as
a. The temperature took a nosedive and dumped a load of white stuff.
b. Just as that cleared up, I shot off to Florida for ten days to join the snowbirds but..... the temperature wasn't much higher than here for the first four days i.e. yes, it did drop to zero Celsius. Good old Frosty Florida. Bollocks.
Yesterday I realised I couldn't really put this off much longer as I wanted LFB back in use. The sun was shining and it was warmer than Florida, so what more could I want? How about getting lucky?
It turned out that the rust wasn't quite as bad as it first appeared. In this pic, on the left the paint has been dragged off with a rotary wire brush in a drill and the first pass to remove the rust has been done. The frame loop has just had the paint removed and shows the extent of the rust. On the right of the pic, the frame hasn't yet been touched. On full size you can just make out the spalling on the brackets.
Before I cut the brackets off, I needed to know where to weld the new ones on. Just about this point I did start wondering about BMW's frame jigs, because after I'd set up a datum point in the middle of the frame loop (i.e. a black line from a marker pen!), I found that the leading edge of one bracket was 64mm forward of the datum point, but the other was 70mm forward of the datum point. Also, the rear of the loop is not square to the frame tubes.
To get the brackets off, I cut through three of the four welds with a 1.0mm cutting disc. There wasn't enough room to get the cutting disc in to slice the fourth weld without hitting the frame loop, so I hit the bracket with a BFH and cold chisel to open up the gap and then cut the fourth weld with a hacksaw.
This amused me - it's under the paint of the front mudguard mount and isn't normally visible. I think there's a '/11' next to the '03' on the right, denoting November '03 and corresponding with the build date of the frame number.
Stage four - paint off and the rust sanded back to bare metal as best I could. The irony of having to wash the bike again to remove the rust dust didn't escape me and of course, within a few minutes that nice clean steel had assumed a slightly yellow hue.
New brackets made from 3mm steel.
-and that's how you clamp them up for gluing to the frame! That mudguard clamp is not going back on. It's being replaced by one made from stainless steel.
After the application of the first lot of glue. The weld isn't as bad as the photograph makes it out to be - I haven't cleaned it up at this point beyond chipping the slag off. The tack for that weld took immediately; however, the one nearest the camera was a bit of a bitch. There was obviously more rust in this area because on first application of the welding rod to tack the bracket, I promptly blew a hole in the rear loop. I hate chasing holes.
I really hate chasing holes.
This one hit stronger metal pretty quickly and, to my relief, didn't take long to close up. The weld is an ugly mess though. Once it had all cooled down I went for a try-fit of the mudguard and seat; perfect. The offset from the datum point is 65mm!
End of play for this week. I need to make up a jig to align the lower brackets and clamp them to the frame, but for that, a trip to a hardware store is called for.
