mentxo
mentxo
For people that lost the hook wrench I have designed it in 3D for printing.
The tool replace the original hook wrench with the purpose of measuring Transmission Oil Level in BMW K100RS 2V
I share the link to download  https://www.thingiverse.com/thing:2842310
Sorry for my low skills in english
Tool for measuring the Gear transmission oil level C_span11
mentxo
mentxo
Hi,
These picture is one of the sources that I have used to design the model of the tool.
All information sources used by me are shared in the picture gallery of the link.
Sent from Topic'it App
Chocolate
Chocolate
Well done muy bien mentxo!
Good job, I’m sure somebody will need/print it.
Davep
Davep
Hi Mentxo,
I am that man who needs this, however, typing on this forum is as computer literate as I get but, I have a friend with a 3d printer, do I just send him the link?
Many thanks
Dave
Tool for measuring the Gear transmission oil level Eu-log10 BMW K100RS 1983 (Main ride)
                      Suzuki GSX 750 ET 1979 (Needs work)
                      Kawasaki Zephyr 750 1992 (Needs hiding)
@Davep wrote:Hi Mentxo,
Many thanks
Dave
You could, but I just used a piece of 3mm metal rod, bent at right angles with enough length in the right angle piece to ensure that it can't fall into the sump.
A small triangular file notch at the max and min levels as shown in Rick G's post completes the zero cost item.  Smile
If you need the shock preload adjuster, they are easily and cheaply obtained.
@Chocolate wrote:Well done muy bien mentxo!
Printing it may well serve you well only once as the oil will make the paper go soggy Tool for measuring the Gear transmission oil level 44271 Tool for measuring the Gear transmission oil level 44271 Tool for measuring the Gear transmission oil level 44271
mentxo
mentxo
I referred 3D printing. I have one 3D printer and I used ABS for print the tool because is most resistant than PLA. Wink
Mentxo.
I use a DIY tool for this job.  I took a length of 1/4" square aluminum stock, jammed it  into a wooden screwdriver handle and cut off the length to 126mm from the handle.  Then I filed a notch 10mm from the cutoff end.  Simple and works a treat.
Tool for measuring the Gear transmission oil level QcV_uQCbD43wcRb71vkLI8mdtCmjPnATGjzLzFIgFiQEm2uB6Pr_P7aUTkLW2qxbXcKG5FjfwIaCaQAd88XEL3NaB_3LLTwgUsc0oJq3_9g7dS2sHwneAJEWZH9zlXT1YXoaOAjzL3euEwMBdSH1BIgIn1h4uZuwA25trJLKJk4du4akC30MhXKTFk5vBN_W7O85Pm-IuB3xvaGy1Ma8ve2otxwtVR-n82VmCGT93MEAB6stpKORrbo0kaBRUASlPmPbs97yTrtxxbBHF-Ngps2cV2V0ej_bPyweHjSE24131SvlaLroTfjNSHEXPfDtmF7rxlWmezCdHtYnqYw6Va3GPzGjYqW2wK5q82ksMexD8vCQIH7bmjbtL7Kb_aMu155CHsH492LZSP01g0bu7ZVGeNtlM94-hDrWpXvib0TgpZyvYDMpqtaKKVkwHhdqTZfeR6vXHw_lalmeIP0tXiGFiEJxAKqRR87fBpmV4vkg2Flua1U3iwJ7I5tbdCnJzhYjKTIDDvcRziSdob6w25IwJuiofDUPbxk-POv2MiYvPlmiezQ3YwrN9o77aQJfNr02cskqZ53sdX6SCXhgqqGm6VNlfZWZc4fY-V4=w640-h480-no
I took a piece of metal coathanger wire, bent a finger loop in it so it wouldn't fall into the transmission.  Flattened the end to make it easier to see the oil and filed a notch at the proper level.  I have them in all my tool kits and in the shop tool box.
Took about 10 minutes to make 4 or them.
nobbylon
nobbylon
I made one from coat hanger wire. Hammered the dip end flat and used a dremel to make the upper limit mark.
