1Back to top Go down   140mm / 8-inch Spal fans £20 Empty 140mm / 8-inch Spal fans £20 on Sun Apr 08, 2018 4:44 pm
'83 K100 upgraded to K100RS spec, '87 K100RT
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
2Back to top Go down   140mm / 8-inch Spal fans £20 Empty Re: 140mm / 8-inch Spal fans £20 on Sun Apr 08, 2018 4:57 pm
If it is the model  I think it is, I have one on one of my bricks.
Not quite a drop in.  On mine, I ground off the mounting ears(they don't line up) and pop riveted it into the OEM mounting ring after cutting a pair of slots in the ring to allow it to fit over the Spal fan.  A not terrible job that took about an hour once the radiator was out.
3Back to top Go down   140mm / 8-inch Spal fans £20 Empty Re: 140mm / 8-inch Spal fans £20 on Sun Apr 08, 2018 11:05 pm
I fit one of these to the three row in me Big Block. Nothing lined up so I sawed an appropriately sized hole in a sheet of aluminium and taper screwed it to that with speed nuts, then attached it with 5mm screws to the edge of the radiator. It's solid and when temps are reached that fan PULLS, but is almost silent. Bonus, it's gotta be good for three horsies out on the open road.
I'm practicing social media distancing; no Facecrack, Wazzup or Instagreedy!
1970 R60/5, '77 R75/7-R100, '85 K100'87 K75C, '87 K100RS, '93 K11-K12 Big Block, '93 K1100RS, '95 R100-Mystic, '96 K1100RS, '98 K1200RS, '00 K1200RS, '02 K1200RS, '03 K1200GT, '04 R1150R'04 R1150RT, '05 K1200S, '06 K1200R, '07 K1200R, '09 K1300GT & 2013 R1200RT-Polizia  - the Beemers in my life I can recall, owned still or sold on, since 1976.
